Turn signal indicator dash lights flash once
Old Dec 3, 2015 | 02:12 PM
bullittandy's Avatar
Default Turn signal indicator dash lights flash once
Just like the title says. All outside turn signals work properly with switch and hazard light switch.
Swapped turn signal flasher with another used one-no joy.
Cleaned contacts in flasher and hazard switch-no joy.
Checked fuses, cleaned contacts of fuse block with deoxit-no joy.
I can hear flasher ticking and lights come on strong once and then not again.
New flasher?
Old Dec 6, 2015 | 06:25 AM
New flasher arrived. New flasher solved problem.
Also created a new problem, I added LED bulbs to warning lights and now the indicated signal flasher lights up brightly, but the opposite side also lights up a small degree (I'm suspecting due to current leakage that is not enough for incandescent bulbs--annoying).
Old Dec 6, 2015 | 09:20 AM
MHF25's Avatar
You will need a resistor. One (total of 2) for the front and one for the rear. RL-650 6 ohm / 50 watt. (I have 2 extras). Also the flasher has to be in correct polarity. Here is a good website to better understand the LED concept with British style electronics. http://classicautoleds.com There is info on resistors and the right type of flasher units.
obwoodie
Dec 12, 2015 05:51 PM
heroooo
Dec 9, 2015 07:17 PM
hawaiianjag
Dec 6, 2015 05:40 PM
Platinum XJR
Dec 6, 2015 02:39 PM
sg18438
Dec 3, 2015 01:13 PM
