V12 5 speed Getrag conversion
Old Aug 7, 2023 | 10:14 AM
Tibbetts's Avatar
Default V12 5 speed Getrag conversion
I am in the middle of this conversion and am in need of the pilot bushing.
O.D.= .765”
I.D.= .50”
we’re stuck until we get this part. Any suggestions will be appreciated.
1992 XJS Convertible V-12
Old Aug 7, 2023 | 05:16 PM
Mozambique's Avatar
Try Simply Performance in UK?
https://simplyperformance.com/performance-parts/
Old Aug 7, 2023 | 06:48 PM
89 Jacobra's Avatar
Active Streak: 30 Days
A machine shop should be able to make one pretty easily. And since it's so simple shouldn't cost too much either. Good Luck hope it helps.
Another thought comes to mind American Powertrain should be able to source one for you. They are known for being able to put a Stick in just about anything.
Jack
Old Aug 7, 2023 | 07:52 PM
Tibbetts's Avatar
Thanks. The pilot bushing that was included was .750”. We were told to add a collar of roughly .0017”. We fabricated a collar and installed the piece. We got it to fit perfectly.
Thanks for your input. Now, on to the 5 sp. Getrag installation.
Old Aug 7, 2023 | 08:21 PM
Mozambique's Avatar
Getrag 5spd + XJS V12 = heaven on earth.
You will not be disappointed!
Old Aug 15, 2023 | 11:52 AM
nickr76's Avatar
Jack
American Powertrain wont be able to help you, their Jag kit places the pilot bearing in the larger/outer recess in the crank, the Getrag(oem)setup places it in the smaller/inner recess in the crank. Should be able to get ine of these from the suppliers as its an OEM part.
Old Aug 15, 2023 | 12:55 PM
Tibbetts's Avatar
Thanks for the input. I appreciate your thoughts. We have resolved the pilot bushing challenge. My mechanic is offfor a couple of weeks. Nupon his return, we should be able to finish fairly quickly. Ben Thomson at Simply Performance has been extremely helpful along the way. I highly recommend them for the conversion. They are currently completing the R&D for a conversion using a Tremec 5 or 6 speed.
Old Sep 21, 2023 | 01:02 PM
Tibbetts's Avatar
Thanks for your input. We finally had one made locally. It fit perfectly.
bullittandy
Jan 16, 2025 05:26 AM
Tibbetts
Feb 5, 2024 04:05 AM
ageyev
Sep 6, 2017 12:00 PM
Tangomike7073
Mar 28, 2016 04:35 AM
christophe37
E type ( XK-E )
Mar 3, 2015 01:35 PM
