V12 5spd conversion - premature clutch throwout bearing failure?
Clarification: The input shaft can be stabilized one of two ways:
1) A bronze *bushing* that is a solid piece, press-fit into the center of the crankshaft, that has a few thousandths clearance to the tip of the transmission input shaft.
2) A roller *bearing* that supports the input shaft tip. That presses into a machined shoulder in the face of the crankshaft boss that the flywheel mounts to (as depicted in the picture above)
Yes, good advice. Thanks!
Too much side shake on the pilot shaft is guaranteed to make the TO have intermittent and sometimes constant pressure directly on to the splines. A new bushing should line things up back to spec. Its a wear item so I doubt the shop is responsible for it, couldve been within spec during the install due to it being within tolerance.
Yes the pilot bushing is a wear item, but the pilot bushing has only 10k km on it, so if it's the cause of the TO wear then something was not quite right with the installation.
Bob_S
Oct 12, 2021 05:43 PM
