V12 5spd conversion - premature clutch throwout bearing failure?
Old Nov 3, 2022 | 07:12 AM
Mozambique's Avatar
Originally Posted by bknorwood
Clarification: The input shaft can be stabilized one of two ways:
1) A bronze *bushing* that is a solid piece, press-fit into the center of the crankshaft, that has a few thousandths clearance to the tip of the transmission input shaft.
2) A roller *bearing* that supports the input shaft tip. That presses into a machined shoulder in the face of the crankshaft boss that the flywheel mounts to (as depicted in the picture above)
Thanks for clarifying!
Old Nov 7, 2022 | 02:53 PM
Brewtech's Avatar
When I experienced this in my Alfa, it was the pilot bushing. Easy fix, but you might as well replace the clutch and TO while youre in there.
Old Nov 7, 2022 | 06:41 PM
Mozambique's Avatar
Yes, good advice. Thanks!
Old Nov 7, 2022 | 08:06 PM
Brewtech's Avatar
Too much side shake on the pilot shaft is guaranteed to make the TO have intermittent and sometimes constant pressure directly on to the splines. A new bushing should line things up back to spec. Its a wear item so I doubt the shop is responsible for it, couldve been within spec during the install due to it being within tolerance.
Old Nov 8, 2022 | 08:58 AM
Mozambique's Avatar
Thanks for your thoughts.
Yes the pilot bushing is a wear item, but the pilot bushing has only 10k km on it, so if it's the cause of the TO wear then something was not quite right with the installation.
Old Nov 8, 2022 | 04:40 PM
Brewtech's Avatar
Yea 10k is too soon
superchargedtr6
E type ( XK-E )
Oct 31, 2022 08:39 AM
Bob_S
Oct 12, 2021 05:43 PM
Segfault
May 29, 2019 05:57 PM
Canadairjet
Jan 4, 2017 07:51 AM
stephenkalas
Nov 17, 2015 03:56 AM
