V12 AAV rebuild with kit, observations.
Old Mar 17, 2020 | 08:28 PM
anyoldiron's Avatar
Banned
Default V12 AAV rebuild with kit, observations.
My 82 was starting at a very upset 400rpm and needed some gentle foot in the beginning, then the revs climbed steadly to about 1400 where it stayed when warm.
Having done the thumb in the airbox test i concluded that is was (perhaps amongest other things) the AAV valve. After reading up on them i decided to get the kit for 80 euros.
The kit is of a good quality, however the replacement ''piston'' is quite loose in the bore, its a lovely bit of SS kit, but by comparison to the other one loose.......................now, how much is too loose that it starts to mess with the vacuum is above my pay grade, but i was not chancing it so i spritzed up my old one and used that.
When dissembling it before grinding you might want to try using a socket extension as a drift and go in from the top.
When assembling it you may want to ''tune'' the thermowhatzit in hot water. l found that mine did not close all the way at 80 odd C so i drove the thermo thing in further and that solved it.
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaand, as has been written, before you do it get the 90% top pipe as it will split, even of you warm it first and ease it off with silicon spray ^&*(ing thing! Either that or if you happen to have a 1987 FZR750 floating about the top rad hose will do in a pinch.
lt now starts and goes to 1000rpm and slowly makes it way down to 800. l havent synced the throttle bodies yet, when i have done so i will fine tune the slow running, but im 3 turns out on the bolt so i should have no problem getting 750rpm.
Not a hard job, the usual fiddly V12 work space but well well worth it!
Old Mar 17, 2020 | 10:37 PM
Dukejag's Avatar
Very cool - sorry cant help but interesting.!
Old Mar 18, 2020 | 03:00 AM
Greg in France's Avatar
Where did you get the kit please?
Old Mar 18, 2020 | 07:12 AM
JayJagJay's Avatar
Hey Man...
Great post. Can you talk a little more about, this? ^^^^^^
Old Mar 18, 2020 | 08:29 AM
anyoldiron's Avatar
Banned
Originally Posted by JayJagJay
Hey Man...
Not without a more definitive question/s no. .
Old Mar 18, 2020 | 08:43 AM
anyoldiron's Avatar
Banned
Stone the Crows, now this is a reversal of information flow.
To be honest i would not recommend this kit unless its a last resort, if you look around you can find them online, otherwise in a pinch i got this sellers information from a video on AAVs by ''Living with a Classic'' on youtube.
Personally i think the piston is too small, it literally wobbles in there and i do not think its a good enough seal to do the job 100% (read Grants article on the subject, he illuminates this point). This is just my opinion, the seller also rebuilds them so im sure they are happy people out there, im just not one of them.
Old Mar 18, 2020 | 08:49 AM
JayJagJay's Avatar
Nevermind... I deciphered your paragraph as a reference to that elbow section of hose that goes from the top of the AAV to the LH intake manifold... A warning about it splitting or cracking when trying to remove or install it - having a spare... No worries. Thanks...
Old Mar 20, 2020 | 07:08 AM
Asdrewq's Avatar
Interesting - thanks for providing feedback on that kit.
Old Mar 28, 2020 | 07:04 PM
purrkittypurr's Avatar
Here's some more info on the subject:
https://forums.jag-lovers.com/t/auxi...guide/370126/3
Old Mar 28, 2020 | 07:47 PM
JayJagJay's Avatar
Does anyone here have any information on which direction the fuel pot is turned for a richer or leaner mixture?
My ECU is in place with the POT access hole in the RH side facing the outer rear fender. As it's supposed to sit. I have a make shift handle on the D shaped POT adjustment post and I'm trying to figure out - do I click it forward or back,,, for say a LEANER mix... Which way is which on that thing?
Any help would be greatly appreciated.
Jeff in Tucson
Jul 10, 2023 05:39 AM
rsmithline
Mar 26, 2021 10:02 PM
VancouverXJ6
Aug 18, 2019 04:14 AM
GhostriderXKR08
Oct 26, 2008 03:20 PM
