V12 Bleed Hosel
Old Jul 4, 2022 | 01:49 PM
Robbo D's Avatar
Default V12 Bleed Hosel
Hi all.
Does anyone know the hose size for the V12 bleed hose CAC5093. I would like to into my local car shop for a piece.
Rob.
Old Jul 4, 2022 | 02:52 PM
orangeblossom's Avatar
Hi Robbo
Manners sells this piece of hose for about £7 so may not be worth shopping around
CAC5093
Old Jul 4, 2022 | 03:06 PM
Robbo D's Avatar
Hi OB.
I did see the Manners hose just a bit wary as to the quality supplied. Can’t really see much in the picture and to be honest after my recent experience with the aftermarket radius arm bushes which were rubbish I would rather pay a bit more and get decent stuff. The hose on the car has the jaguar part number on it not the hose size. If I can get the size I can get a pice of hose dropped in to the office by one of our work suppliers Express Radiators in Norwich.
Rob.
Old Jul 4, 2022 | 04:07 PM
Doug's Avatar
Originally Posted by Robbo D
Hi all.
Rob.
Where does it fit and what does it do?
If it's one of those steam relief hoses attaching the the metal pipes above the radiator then 1/4"ID should do the trick. I'll look at mine later.
Old Jul 5, 2022 | 12:30 AM
Robbo D's Avatar
Hi Doug.
Yes these are the boys. I need to replace the one that runs from the just under the centre filling point.
Rob.
Old Jul 5, 2022 | 02:22 AM
Greg in France's Avatar
Manners hose are excellent. You need have no worries.
Old Jul 5, 2022 | 07:44 AM
Robbo D's Avatar
Greg which one to go for ? There are 2 on manners site one has WOV after the part number but is cheaper. I assume this is woven so would have thought it would be the more expensive option. I will await your advice before ordering.
Rob.
Old Jul 5, 2022 | 09:30 AM
ptjs1's Avatar
Rob,
There are 3 options for you.
The part number is actually CAC50931, not CAC5093
The original Jaguar part (CAC50931) Is about £29
Manners do an OEM part CAC50931# at about £8.50
Then they also do a pattern part, confusingly named CAC5093/1*WOV also about £8.50
The * indicates it's an aftermarket pattern part. And the CAC5093/1 seems to be just an error in their website part naming.
I'd go for the OEM one CAC50931# as you can trust Manners if they say its OEM.
Good luck
Paul
Old Jul 7, 2022 | 01:52 PM
Robbo D's Avatar
Hose from Manners fitted today. Quality looks fine so all should be good.
Rob.
ronbros
Nov 1, 2023 09:15 AM
Andreas Schmieg
US Midwest
Jan 27, 2017 07:20 PM
Andreas Schmieg
Jan 27, 2017 07:15 PM
FastCat85
Nov 25, 2015 06:38 PM
velder
Jul 6, 2011 01:28 PM
