V12 cylinder head jacking/removal tool hire in the UK
Old May 26, 2018 | 03:10 PM
Clouder's Avatar
Default V12 cylinder head jacking/removal tool hire in the UK
Hi,
Does anyone know if I can hire a V12 head jacking/removal tool in the UK? I have stripped my engine down to the heads and need the jacking removal tool. I know I can purchase them, but it difficult to justify the expense for a one off requirement.
Any guidance would be appreciated.
Andy
Old May 26, 2018 | 08:54 PM
unimoged's Avatar
Have you considered making a tool, it is a flat 1 inch thick plate with holes that allow the camshaft cap bolts to go through and taps for longer bolts that mesh against the head studs.
here is one for 250 on ebay uk: https://www.ebay.co.uk/itm/Jaguar-V1...-/173116248576
Old Jun 3, 2018 | 09:51 AM
Clouder's Avatar
Default Jig
Ended up making my own. Now to test it on the engine!!
Attached Thumbnails V12 cylinder head jacking/removal tool hire in the UK-94a07259-069b-47ef-b791-de9fda3d2f9c.jpeg   V12 cylinder head jacking/removal tool hire in the UK-d1aab006-74fb-4377-b0f6-c22768c683eb.jpeg
Old Jun 3, 2018 | 04:21 PM
Steve M's Avatar
The Jaguar Enthusiasts Club hire these out I think; worth a punt.
https://jec.org.uk/
Old Jun 8, 2024 | 11:38 PM
watto700's Avatar
G'day Gents,
A question on the removal of V12 heads, is it possible to remove the head studs from the block with the heads still in place or is it just impossible to get a good enough grip on the stud ends to be able to turn them?
Not that I need to but I was just wondering.
Cheers,
Jeff.
Old Jun 9, 2024 | 12:55 AM
Greg in France's Avatar
Impossible. The studs go through water passages and the holes in the head the studs go through get clogged up with general debris and stuff over the years, right through the casting and stuck. This is the reason, even with a tool, that the heads can be so very hard to remove.
Old Jun 9, 2024 | 09:52 AM
Mguar's Avatar
As has been said crud builds up on the studs.
You will have a much better time of it if you get something to remove the crud.
30% vinegar works. Not grocery store vinegar that’s 6% at best. A good hardware store will have it.
You can also use radiator flush. Fill the coolant hose with it. ( remember to plug the water pump intake) let it sit for a few day then flush it out. Repeat until everything comes out clear.
Per
Mar 25, 2023 07:55 PM
Clouder
Jun 10, 2018 04:17 PM
Kasper
Sep 7, 2017 08:26 AM
deelli
General Tech Help
Jan 14, 2015 05:43 PM
Safari
Nov 12, 2014 08:38 AM
