V12 FPR
Old Feb 5, 2017 | 10:29 AM
Daim's Avatar
Default V12 FPR
Bonjour,
The V12 has two fuel pressure regulators (FPR). One return and one feed. I know the feed can be ditched... Bit I still will fit one. Regarding the FPR as such: does it matter if original or aftermarket? They range from around €40 for an aftermarket one to €140 for an original...
Damien
Old Feb 5, 2017 | 10:45 AM
Doug's Avatar
I've used aftermarket FPRs and Jags and others with no problems, knock wood.
You know my usual view on parts: you really don't now what you're getting these days. Brand name on the box assures absolutely nothing.
Old Feb 5, 2017 | 10:49 AM
Daim's Avatar
Indeed you're right Doug. OEM isn't always best...
I can't really be arsed to pay that mich for an FPR will will fail sometime anyway. And howmbad can an aftermarket part be?
Old Feb 6, 2017 | 06:53 AM
user 652867429824's Avatar
when I did mine, I replace both FPR and used aftermarket, running great
Old Feb 6, 2017 | 04:23 PM
warrjon's Avatar
Jaguar did away with the inlet FPR from 1992 on the V12, my 6.0L did not have one.
Old Feb 10, 2017 | 02:47 PM
Jonathan-W's Avatar
too true my 1992 only has the one and it is the 5.3 liter... the switch over to the 6.0...
a lot of transitional stuff going on that year...
Old Feb 10, 2017 | 03:05 PM
Jagboi64's Avatar
I think the originals were Bosch, so buying a Bosch in a Bosch box rather than in Jaguar box should work well and save a lot of money!
Old Feb 10, 2017 | 03:11 PM
Daim's Avatar
Well I've got two old ones here and they have Lucas stickers but what seems to be a Bosch number...
Old Feb 10, 2017 | 03:13 PM
warrjon's Avatar
Very common, the Lucas ECU is actually Bosch too.
Old Feb 11, 2017 | 02:18 AM
Greg in France's Avatar
I swapped mine for a D Manners aftermarket job at less than half the price, works perfectly.
Greg
Old Feb 11, 2017 | 04:16 AM
Daim's Avatar
So, I grabbed my two spare FPRs and wanted to make sure they were the right ones... The Bosch numbers are:
0 280 160 229 (2.5 Bar, B-Bank side), Lucas 73232B
0 280 150 712, Lucas 73369A
According to some scources, the 712 is wrong and should be a different one.
Are these numbers right? Just want to make sure I get the right ones as I will be using both (even though one should be enough on the B-Bank side).
Old Feb 11, 2017 | 01:07 PM
Jagboi64's Avatar
The right side (inlet) regulator was specified at 45 psi, the left (outlet) at 36 psi.
Are you sure of the numbers? 0280150712 comes up as a Saab injector, however 0280160712 comes up as a regulator.
The number I am seeing for the inlet side is 0280160234, which is 3 bar. As long as the pressure rating and the fittings are the same, it should be fine to use.
Old Feb 13, 2017 | 01:33 PM
melhookv12's Avatar
I was lead to believe the one on the inlet size actually works as a fuel damper.
Pre-HE are adjustable, later ones aren't.
Old Feb 13, 2017 | 05:12 PM
baxtor's Avatar
The HE regulator can be adjusted but only for more pressure and it is not reversable.
Old Feb 14, 2017 | 04:27 AM
melhookv12's Avatar
therefore not adjustable as such. Smiley face
