V12 grille badge
Old Mar 19, 2017 | 04:27 PM
leo_denmark's Avatar
Default V12 grille badge
Hi
The XJ-S is the S-type of the XJ, and my car actually has an S-badge instead of the much more common V12 badge. Anyone else with S-badge ?
Old Mar 19, 2017 | 06:20 PM
JigJag's Avatar
I've noted those early XJS "S-Type" ads out there. As an Ad person I can't say they're very well designed, but more to my point they clearly referred to the XJS as the "S-type" at the time. Later the "S-type" appeared and somewhere in between they dropped the "S-type" label for the XJS.
Istanbul not Constantinople.
Old Mar 20, 2017 | 12:36 AM
Daim's Avatar
It's not the S type of the XJ... The S type is always a saloon/sedan, hence the name plate for the last S type. The S means SPORT. So XJ-Sport. In Relation to the XJ-Coupé for the short lived 2 door coupé from the early 70ies.
It could also mean Special but I can't find the source anymore...
Iirc only the 3.6l got the S badge. S for slow Haha... Sorry for the pun!
Old Mar 20, 2017 | 01:09 AM
You're probably right about the S for Sport, but my engine had 12 cylinders last time I looked, and I dont think a PO would have removed the V12 badge... ?
Old Mar 20, 2017 | 01:10 AM
Daim's Avatar
It is a 2 min job to replace the grill...
IIRC your engine was replaced. The grill needs to be removed to do that.
Old Mar 20, 2017 | 03:22 AM
The engine was changed twice: From original preHE to another preHE in 1989 and finally to the current 1989 HE engine in 1996.
I suppose the grille would stay on the bonnet assembly, which then is removed when doing major jobs like this ?
Anyway: If the S-badge is wrong for a V12, then I need to change it, no matter why it has been mounted...
Old Mar 20, 2017 | 03:52 AM
Daim's Avatar
Nope the grill needs to be removed to remove the 4 screws for the bonnet hinges... And as the Grills are just cheap plastic, they tendiere to crack. Wouldn't surprise me if the previous owners fitted a used grill...
Old Mar 21, 2017 | 07:13 PM
JigJag's Avatar
Here are a few of those "S-Type" ads I was speaking of...
Old Mar 22, 2017 | 12:12 AM
I had seen some of these old adds before, and I was therefore thinking, that my S-badge could actually be correct for my 1977 vintage ?
Old Mar 22, 2017 | 01:39 AM
Daim's Avatar
Iirc only the US models were called S-Type. ROW was just XJ-S. Like the E-Type was the XKE in the States and ROW only knew E-Type...
Old Mar 22, 2017 | 06:35 AM
Doug's Avatar
I think you're right regarding the USA market. Oddly, "S-Type" and "XJ-S" were both used in the very same advertising. The "S-Type" identification extended even into the early 80s, at least.....
http://www.jag-lovers.org/brochures/...0/77xjsa_l.jpg
http://www.jag-lovers.org/brochures/...m-2-77_2_l.jpg
Jag-lovers brochures - a 1981 XJ-S Brochure Page
Jag-lovers brochures - a 1978 XJ-S Brochure Page
No mention of "S-Type" in this UK brochure:
Jag-lovers brochures - a 1977 XJ-S Brochure Page
Old Mar 22, 2017 | 06:43 AM
JigJag's Avatar
Jag-lovers with their passive-aggressive deep link blocking pic amused me this morning.
"Glad you found our image useful! ... so here's a useless pic"
Old Mar 22, 2017 | 08:26 AM
NJ2003XJ8's Avatar
This 'S' badge when shiny adds at least 5HP!
Old Mar 22, 2017 | 09:30 AM
Daim's Avatar
At least! I mean, if you clean the rins, your at least 10 hp higher...
Old Mar 22, 2017 | 09:54 AM
NJ2003XJ8's Avatar
Yep, this 'S' is for 'SUPER-FAST' !
Old Mar 22, 2017 | 10:19 AM
Daim's Avatar
XJ-SUPRA
Old Mar 24, 2017 | 10:16 AM
Benj628's Avatar
My '96 had the black plastic grille which I have now replaced with an old chrome one, and I specifically got an S badge for it, the V12 wouldn't do for a 6 cyl.
Best I can discern, the S badge was used on the 89-91 6 cyl models, then the grill was changed to the black plastic one with no badge on it.
Old Mar 24, 2017 | 11:15 AM
Daim's Avatar
That is what I had in memory. The V12 always had a V12 badge and the 6 bangers had the S. Why advertise a 6 cylinder if the 12 is the TOTR
Old Jul 13, 2017 | 01:00 PM
coventryfan's Avatar
Does anyone have a lead on a nice V12 grille emblem? Mine is cracked
