Vaccum system overhaul
Old Jun 12, 2013 | 03:44 PM
Pif's Avatar
Pif
Default Vaccum system overhaul
How much line, and of what size, would I need to redo the entire vacuum system on a 1985 XJS?
Old Jun 13, 2013 | 09:01 AM
Greg in France's Avatar
Assuming you are referring to the ignition vac lines, this is what I did:
  1. remove all of it, pipes, little solenoids etc etc and block off any unused ports to the manifold.
  2. renew the vac capsule
  3. run a single vac line from the underneath of the A bank throttle body (where there is an outlet correctly sized) to the vac capsule
  4. disconnect the loom from the water temp switch on the A bank rear water manifold and insulate the ends and tie them off somewhere;
This will deactivate the 15 minute strat-up timer which just uses extra fuel to no purpose, and you will notice no adverse change in the cars performance. I was advised to do this by the Jaguar Enthusiasts Club guru, the great David Marks, and my car has been like this for years. Highly recommended
greg
2001 White XJ8
Feb 25, 2021 05:02 PM
Roger95
Sep 25, 2015 02:05 PM
sogood
Sep 15, 2015 07:35 AM
scatcat
Sep 15, 2015 06:55 AM
avern1
Sep 8, 2015 06:25 PM
