Warning light... What is this?
Old Mar 28, 2021 | 03:14 PM
dborthwick's Avatar
Default Warning light... What is this?
Hi, when I'm driving along the revs will go up but the speed remains the same.almost like I'm not changing gear... then this warning light pops up and I have no clue what it is. Please help!
Old Mar 28, 2021 | 04:11 PM
mghirsch's Avatar
Transmission fault.
Old Mar 28, 2021 | 04:22 PM
dborthwick's Avatar
Well that's no good. Thanks!
Old Mar 28, 2021 | 06:14 PM
Dleit53's Avatar
I have heard that this often comes on because of low fluid. If you have not checked already, check your transmission fluid. Check it when warm, with the engine running.
Old Mar 29, 2021 | 10:27 AM
mghirsch's Avatar
Sounds like you may have a bad solenoid. To be sure, run diagnostics. I had the light come on in mine, and I had a Jag dealer run diagnostics. Was a solenoid fault. Not a bad job to replace. There are three (IIRC) and not knowing which one, I replaced all three, and the filter at the same time. My L480E has a drain plug. Drained the fluid, removed the pan, replaced the solenoids and filter, reassembled. Light was off.
Old Mar 29, 2021 | 12:42 PM
Flint Ironstag's Avatar
That's one light I have never experienced on mine!
afterburner1
Sep 26, 2020 10:54 PM
Josh Knight
May 1, 2020 02:14 PM
Gary4.0
Dec 27, 2019 11:46 AM
John Sentineal
Canada
Aug 17, 2018 03:51 PM
StephanWolf
Nov 7, 2010 08:40 PM
