Waterless antifreeze?
Old Feb 13, 2013 | 09:34 AM
Scotlad's Avatar
Default Waterless antifreeze?
I guess I am a little late to the party but I had never heard of it until I caught an episode of Wheeler Dealers where they were working on a Triumph TR6. The idea sounds great as the boiling point goes way up over the regular mix but the thing I was most interested in was the elimination of internal corrosion in the engine. I have a 93 XJS with the AJ6 engine and I have heard of head gasket problems with this motor due mostly to corrosion between the head and the block. The downside to it seems to be the price ($40.00 a gallon) and the fact that you have to remove all the water from the system. For those of us that our cars sit in the garage over the winter, a non corrosive (and non toxic) formula seems to be a good idea. Evans seems to be one of the brands available and they even interview Jay Leno as he has used it for quite a while on some of his collector cars. Any thoughts on this product or do any of you have experience with it already?
Old Feb 13, 2013 | 09:55 AM
Scotlad's Avatar
One other thing I failed to mention is that this product (Evans brand) is permanent you never have to change it.
Old Feb 13, 2013 | 10:13 AM
Five Speed's Avatar
If its that good , why dont all motor manufacturers install it from new ...Price ???? Snake oil ??? Regular Anti freeze is the best item for the job ??
Old Feb 13, 2013 | 04:16 PM
ronbros's Avatar
works great EVANS, used it for 8yrs in my RX7, no corrosion when i changed a water pump, absolutly no rust or sediment, also used it in my BBC Camaro, never any over heat, 375* boil point.
i want to put it in my V12, but as you say it is expensive, but i will do it soon.
it was developed for cooling hydralic systems in Black Hawks, for extreme temps when running combat missions, and cant back off.
a drawback is it is slippery if you blow a hose or something, and it gets on tires.
ejjbee
Jan 26, 2019 11:53 AM
drpsmith
Oct 16, 2015 08:23 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
kevo
Sep 8, 2015 09:45 AM
BuckMR2
May 17, 2007 11:57 AM
