Which way to turn radiator drain?
Old Mar 25, 2013 | 06:35 PM
J_C_R's Avatar
Default Which way to turn radiator drain?
My '87 has the long handle that apparently one must turn one way or the other to drain the radiator. Mine is stuck, and I don't want to force it the wrong way. Which way should it turn to drian?
Thanks,
John
1987 XJS V12, 62000 miles
Old Mar 25, 2013 | 08:07 PM
Jagfixer's Avatar
Soak it with a penetrating oil and let set, then soak again, then start trying to move it back and forth, until it opens and starts draining. Since it points straight out, either way will open it, but try soaking and try to move. If it doesn't free pull lower hose to drain.
aholbro1
Dec 29, 2024 06:46 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Scarecrow
Mar 28, 2016 03:17 AM
Saturbo
Sep 8, 2015 07:35 PM
obwoodie
Sep 3, 2015 07:45 PM
