Weird ignition issue
Old Jul 18, 2018 | 11:21 AM
Segfault's Avatar
Default Weird ignition timing issue
My car has been sitting for 15 years alright. Now, having a second life, I'm slowly addressing all the million issues it has. I'm driving it every day a little. Engine didn't run well. I was planning sending injectors in for check. And replacing the fuel filter is in order. And checking the fuel pressure is planned.
Today something happened. I was light on the gas and revved over 2500, and suddenly it jumped forward like a young Jaguar. Then the coolant temperature dropped. So now I'm guessing it is not fuel issue at all causing poor performance. Ignition was too retarded. I'm wondering why and how the heck it suddenly started working. Now sometimes it jumps forward when revved over 2500 and sometimes it doesn't. Shall I take the distributor apart or there may be some XJ-S specific vacuum issue? I admit I haven't read thru EFI/Ignition manual yet.
Old Jul 18, 2018 | 11:31 AM
JigJag's Avatar
A sticky centrifugal advance that releases when revved might cause such behavior. Open the dizzy and see if you can advance the rotor and, when released, that it snaps back smartly.
Old Jul 18, 2018 | 12:12 PM
Segfault's Avatar
Before I tear the distributor apart, is there a repair kit with new springs and whatnot sold somewhere?
Old Jul 18, 2018 | 12:33 PM
J_C_R's Avatar
Have you looked at Palm's book? It covers this topic extensively, including how to rebuild the distributor.
Thanks,
John
1987 XJ-S V12
Old Jul 18, 2018 | 01:55 PM
Jagboi64's Avatar
The springs shouldn't need to be replaced. However, the workings are probably gummed up, so taking it apart and a good cleaning will improve things. Make sure that the vacuum advance mechanism actually moves under vacuum, I bought a new one and the rotating mechanism was frozen in place. I ended up cleaning the old one and reusing it with a new vacuum capsule. Once all the moving parts are clean, I lubricated them with synthetic ATF, to withstand the heat.
Old Jul 18, 2018 | 03:30 PM
Segfault's Avatar
Originally Posted by Kirby's Book
Unless your distributor has been overhauled, it is seized right now. Period. This has proven to be a 100% failure rate, every time, every car, there simply is no doubt anymore. And a seized advance unit results in low power, overheating and major engine damage if not corrected. If you are not absolutely positive that your distributor has been overhauled already, it is imperative that you schedule an overhaul as soon as possible -- and drive the car very gently or not at all until it’s done.
I put this here as a warning for people who may read this thread in the future.
ALLEN68
Oct 30, 2023 02:11 PM
MLRocafella85
Jun 18, 2011 02:19 PM
WillieE
May 17, 2011 11:14 AM
