What is the Anti Freeze Mix for an XJS V12?
Old Oct 23, 2016 | 04:12 AM
orangeblossom's Avatar
Default What is the Anti Freeze Mix for an XJS V12?
Time to fill up with Antifreeze
I bought a 20L Drum
How much Water does the Radiator Hold and what proportion of Anti Freeze should I put in?
Old Oct 23, 2016 | 04:21 AM
Greg in France's Avatar
50% antifreeze, 50% soft or distilled water. Mix it up in advance, about 20 pints, but some will be in there still. Then any left over keep for topping up, bleeding top up etc.
Greg
Old Oct 23, 2016 | 05:09 AM
Daim's Avatar
Make sure you, if using NON factory spec antifreeze, either give it a full flush or use some universal compatible stuff. I only use Prestone Antifreeze concentration now, after my V12 had the wrong coolant used before and it all reacted casing damage to my water pump and loads of leaks.
This how my water pump looked after the antifreeze was replaced...
Old Oct 23, 2016 | 05:44 AM
OMG!
Cheers Daim.
Old Oct 23, 2016 | 05:47 AM
Greg
Hi Greg
I'm not sure if our Water is hard or Soft?
Does it really matter that much if it isn't?
Old Oct 23, 2016 | 07:56 AM
You are in the south east aren't you OB? The water will be extremely hard, you should really use distilled water.
Old Oct 23, 2016 | 09:03 AM
Cheers Norri
I'll Order some right now!
Old Oct 23, 2016 | 10:15 AM
If you have a rainwater butt, rainwater is fine too.
Greg
Old Oct 23, 2016 | 11:23 AM
Daim's Avatar
Greg
Just sieve it first
Old Oct 23, 2016 | 01:54 PM
Greg
Hi Greg
Too Late (Lol)
I've just ordered 25L for a Tenner.
Which will give me 50L to service the Fleet.
Old Oct 23, 2016 | 03:28 PM
BC XJS's Avatar
The mix of antifreeze to water depends on how much protection you need. What is max low temp in your region. Use that and lower by 10-15 degrees for global warming and weird weather. I cracked a 340 V8 25 years ago so I over protect. We never had -18 c before in Vancouver
Old Oct 23, 2016 | 03:55 PM
Hi BC
We're lucky to see Minus 5 down our way but I'll still keep it 50/50 its a lot cheaper than another new Rad, although that had Mechanical Damage.
Old Oct 24, 2016 | 01:28 AM
baxtor's Avatar
I believe antifreeze should be run at 50/50. Running at a stronger concentration is not recommended due to the lower heat transfer ability of the concentrate verses water.
Old Oct 27, 2016 | 09:46 AM
Paul_59's Avatar
Banned
Jaguar used to state 40% antifreeze, 60% water for UK.
As others have mentioned it's based on amount of frost protection needed as per lowest winter temperature expected.
Important point also is the more anti freeze (less water) leads to less ability to transfer heat from engine to radiator
Old Oct 27, 2016 | 10:12 AM
JagCad's Avatar
My one bit:
I'd not fret over 40% or 50 %?? Unless, I lived in really cold country.
Even when I served in Germany from 52 to 55, our military vehicles got along on 50%. Moat of us followed suit on our personal cars. In my case the 49 Mercury I brought over and later the first and only brand new car, I ever bought, a BRG MG TD. Oh, and the Belgian assembled 50 Chevrolet that replaced it. No issues.
Now, I merely add a gallon and top off with "good" water...
Hard water is the presence of a high mineral content. Rough and ready measures. White stuff on plumbing outlets? Get in the shower and "lather up". Lots of bubbles or hard to get a lather? Bubbly means soft.
We enjoy good water around here. But, just up the road, not so much.
Carl
Old Oct 27, 2016 | 11:53 AM
Originally Posted by JagCad
My one bit:
Carl
Hi Carl
I've gone for a 50/50 Mix with deionised Water, more about that later on my Cherry Resto Thread.
