What did you do to or buy for your XJ-S/XJS today?
  #1401
Old 08-06-2020, 08:21 AM
Timeisrelative's Avatar
Probably beside the 10mm socket😁😁
  #1402
Old 08-06-2020, 05:11 PM
jerry_hoback's Avatar
Received 1,137 Likes on 797 Posts
Huh. I thought I looked there, but I'll check again. Thanks!
Timeisrelative (08-06-2020)
  #1403
Old 08-08-2020, 02:36 PM
Chap1958's Avatar
Tropical storm Isaias whipped through our area knocking out power at home and at work. Our generator is working overtime, and the internet came back on this morning. I spent the last 2 days detailing to my heart's content...
The following 4 users liked this post by Chap1958:
Bez74 (08-11-2020), Greg in France (08-08-2020), Rick25 (08-09-2020), Timeisrelative (08-08-2020)
  #1404
Old 08-08-2020, 11:20 PM
VancouverXJ6's Avatar
looks great! Do you use clearcoat sealant? I have been loving Jetseal lately.
I ordered the AC rebuild kit...will be attempting to do a rebuild to end my ac leak and belt it directly to the engine since I deleted my 90lb useless air pump.
  #1405
Old 08-09-2020, 06:22 AM
Chap1958's Avatar
No, just simonize wax. The car was pretty clean, but I think it has been a long time since she had a deep clean. The car is in really great condition cosmetically. Mechanically it's not bad and will need some attention to basic maintenance on age related stuff. Everything is working as it should at the moment. I am planning to bring it by a local garage that specializes in older Jaguars and have them take a look at it. I am just too unfamiliar with it at this point, and we still have a few months of really good weather and I'd like to enjoy some of it driving before I start going through it. There'll be 6 months of winter for that!!
  #1406
Old 08-12-2020, 03:14 PM
Excised the 400lb Fred Flinstone-era AC compressor and nearly threw my back out doing so, also received my 10mm racing spec cable leads finally, AND new filter box housing to build an alternative cold-air intake system.
I intend to (in no particular order)
Rebuild AC compressor and replace the blown rings, belt it directly to the wheel no idle arm.
Steamclean the filthy dusty engine bay and possibly fit a fine mesh behind the grilles to prevent dust build up
Ceramic coat my spare filter housing - manifolds - cam covers - exhaust headers for the ultimate cold air/head reduction setup
Replace garbage off-brand cable leads
Drink excessively.
Engine bay picture without AC unit - beer can for scale.
Greg in France (08-13-2020)
  #1407
Old 08-14-2020, 05:54 PM
JayJagJay's Avatar
Received 1,292 Likes on 893 Posts
They SAY,,, they like to be driven... So that's all I did...
Hit a few country dirt roads to boot.
Longest trip in a day... 450miles...
I think she was happy bout it...
Las couple days. Removed carbon canister and replaced that short hose from the pump to the bridge pipe.
The following 3 users liked this post by JayJagJay:
Grant Francis (08-16-2020), Timeisrelative (08-14-2020), VancouverXJ6 (08-16-2020)
  #1408
Old 08-16-2020, 03:45 AM
rgp's Avatar
rgp
rgp is online now
Default goodbye pcv valv
my pcv valve had packed up and i had been toying with the idea of an oil catch tank, so i set about buying a kit of parts to fit one, i cut the end of the pcv and removed the innards and refitted it to the air filter, i sealed the hole in the air filter ( I wonder now if that's a good idea) that would normally let any oil in, i mounted a small glass oil catch tank to the wing brace bar, fitted a 19mm-10mm reducer to the air filter attachment and the crank case rubber elbow and connected hoses to and from the catch tank, end result absolutely no change to engine running, and with 200 miles + and significant signs of oil in the catcher whole kit of parts under £100.00
The following 2 users liked this post by rgp:
Greg in France (08-16-2020), Timeisrelative (08-16-2020)
  #1409
Old 08-16-2020, 06:44 AM
Greg in France's Avatar
Received 9,162 Likes on 5,386 Posts
Rex
Where did you find that nice glass bowl catch tank? A very smart job overall.
  #1410
Old 08-16-2020, 07:39 AM
rgp's Avatar
rgp
rgp is online now
Amazon, ile pm you a link when I get home later
Greg in France (08-18-2020)
  #1411
Old 08-16-2020, 10:52 PM
Did you test suction from the engine breather elbow before plugging it all in? I only ask because I was suprised how much it sucks at idle, solved all my oil leaks while the engine is running. Had my unit for over a month now very very little collected so far but peace of mind knowing its not clogging up the intakes etc.
rgp (08-17-2020)
  #1412
Old 08-17-2020, 05:24 PM
FinCat's Avatar
Came to nightshift with Jag, spent 4 hours by washing and applying fresh wax and deep shine. Think she is fine. Did same for my Rover last night, did i say that i actually hate washing and waxing... Now, back to work...
Should not play this much on nightshifts, not 25y stallion any more. I can feel all this effort soon.
The following 3 users liked this post by FinCat:
Greg in France (08-18-2020), rgp (08-18-2020), Timeisrelative (08-17-2020)
  #1413
Old 08-20-2020, 10:48 PM
New resonator exhaust tips, abit larger than I expected but it gave the growl I wanted and seemed to tone down the unpleasant notes.
https://www.youtube.com/watch?v=LU1I...ature=youtu.be
Xjeffs (08-22-2020)
  #1414
Old 08-21-2020, 02:18 PM
So just tips, or did you change anything else? Sounds good
  #1415
Old 08-21-2020, 02:36 PM
Already had gutted cats, 2" pipes X-pipe and high flow mufflers to side exits but the tips really help Im surprised. It only took 5 years of fking with the exhaust to produce something decent...LESSON LEARNED.
The following 2 users liked this post by VancouverXJ6:
eurolat (08-22-2020), Timeisrelative (08-21-2020)
  #1416
Old 08-22-2020, 06:52 AM
BenKenobi's Avatar
Easier to list what I didn't buy .....
Biggest item a pair of Quick Jack BL-5000SLX - not exactly for the XJS only but the XJS was the motivator so I can drop the subframes.
I purchased the SLX because I can use this on my other cars that are slightly smaller, you can also buy an EXT addition if larger is needed because of jacking locations.
Bought an ex MOT station gas analyser - (previously used a Gunsons G4125) so this will be something of a restoration in itself.
Over the course of the week I've ordered just about every bush, pipe, hose, caliper rebuild stuff, for front and rear, likje I said - really too much to list - I did order and subsequently cancel a radiator due to incompatibility - next on the list is 5 tyres -
The way the weather seems to be headed though I'm now not so sure I'll get this done before the winter hits us and I don't work outside in winter (yeh I'm a wimp - deal with it - the years of rolling around under a car in the cold and wet are behind me) - garage us regrettably full
  #1417
Old 08-22-2020, 04:40 PM
Chap1958's Avatar
Bought a nice set of used rims and new tires and got them on the car today. Couldn't wait to go for a spin. A few minutes in I noticed the speedometer had stopped working, after about 10 minutes started working again. Hmmn. It was warm here today and the A/C is working pretty good. I then realized I never tried the heater. That wasn't so good, no heat. Switched back to the A/C. Now that stopped blowing out the front vents and was coming out on the floor, defroster, and a little out the A/C vents. Oh well, other than that she is running well.
The following 3 users liked this post by Chap1958:
Dukejag (08-23-2020), FinCat (08-23-2020), Greg in France (08-23-2020)
  #1418
Old 08-23-2020, 03:13 AM
FinCat's Avatar
I like these wheels, my Jag have them too.
  #1419
Old 08-23-2020, 02:19 PM
spooky horn's Avatar
I replaced the left hand side coolant temperature sensor... Runs even better when cold now. Between that and fixing the fuel line pressure I seem to have mostly eliminated hard starts. Feeling pretty good even if they're little things
  #1420
Old 08-23-2020, 03:03 PM
garethashenden's Avatar
I replaced the windscreen gasket yesterday and sealed it today. It was a PITA, but it works. Just had a thunderstorm and the inside of the car is dry. Still need to put the trim and wipers back on.
The following 2 users liked this post by garethashenden:
spooky horn (08-23-2020), Timeisrelative (08-23-2020)
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
