What is this filter for?
Old Jun 4, 2013 | 12:38 PM
ukester's Avatar
Default What is this filter for?
A picture
Old Jun 4, 2013 | 12:53 PM
Brake buster's Avatar
that filter is for the distributor ,
follow the hose into the engine, and you will see it go to the distributor, there is another hose that goes to the air feed to the AAV behind the left air filter box , this is the pipe that sucks the air through the distributor from that filter
BB
Old Jun 4, 2013 | 12:56 PM
Oddrods's Avatar
What is the "AAV"?
Old Jun 4, 2013 | 02:25 PM
ukester's Avatar
which distributor the ignition or some sort of vacuum?
Old Jun 4, 2013 | 02:50 PM
Flint Ironstag's Avatar
AAV = Auxiliary Air Valve. I think.
Old Jun 4, 2013 | 03:04 PM
rgp's Avatar
rgp
its a dizzy breather, end
Old Jun 4, 2013 | 05:48 PM
Lenoat702's Avatar
Are these filters supposed to be changed?
Old Jun 4, 2013 | 07:05 PM
J_C_R's Avatar
I don't think it ever hurts to change a dirty filter :-) and given how cheap and easy they are to replace it's a no-brainer.
I didn't care for the way mine looked just hanging out inside the engine compartment, so I routed it forward and stuck a bit of hose on the other end. Makes things a bit neater, although you couldn't tell it by this picture.
Thanks,
John
1987 XJ-S V12, 62,000 miles
kthrash
Feb 25, 2019 10:20 AM
redxk8
Oct 4, 2015 08:28 AM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
