What goes into this hole?
Old Aug 4, 2014 | 06:20 AM
Hoppy's Avatar
Default What goes into this hole?
Hi All,
Getting ready for Concours this month.
My 1990 RHD convertible V12 has a 25mm hole right up in the very top LHS of the engine bay behind the ABS pump on the inner fender/guard. What's this for? do I just need to plug it up with a grommet?.
Appreciate any feedback Thanks
Old Aug 4, 2014 | 06:55 AM
baxtor's Avatar
Originally Posted by Hoppy
Hi All,
I have an '89 and that is where my wires to siren for security system enter. I would guess without those wires it would simply be blanked off.
Old Aug 4, 2014 | 12:20 PM
Daim's Avatar
There should be a pipe running from the header tank to there... That hole is then filled with a rubber grommet.
Old Aug 5, 2014 | 06:37 AM
Hoppy's Avatar
I found a rubber tube with an in line filter hanging loose below the ABS pump? this tube runs across the firewall behind the motor - i'll trace it out tomorrow. The filter would need a hose attached o the outlet to fit through the hole via a grommet.
Old Aug 5, 2014 | 06:51 AM
baxtor's Avatar
That will be from the marelli distributor vent system. There will be another leading to the vacuum source.
See "distributor fire" thread
Old Aug 6, 2014 | 02:39 AM
Hoppy's Avatar
OK, the header tank pipe goes into the hole below and in front of this hole....
I've got a grommet in the hole now - see photo.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Poet
Feb 7, 2025 02:18 PM
Mac Allan
Jul 20, 2020 05:46 PM
MrWhite
33
Oct 22, 2015 10:29 AM
