What Stereo Unit (ICE) would you recommend for an XJS V12 to replace the Pull Out
From your photo I can see that on the later convertibles the rear speakers are mounted on the sides pointing toward each other. On the 89-91, they are mounted low on the face of the storage bin, and point directly at the back of the seats in front of them.
Because I drive with the seat all the way back, there is only about 2" of space from the speaker grill to the seat back.
Can't win them all.
Cheers,
OB,
I spent a bit more (£125) when I did mine back in 2014, But I was specifically looking for an Alpine model with the various functionality that I wanted. It's important to decide exactly what you want and then work out where you'll compromise. For example I decided that analogue FM radio would probably continue longer than we were led to believe, so decided that I wouldn't invest in a DAB radio which required a separate aerial.
It may be slightly different in your pre-facelift car but I took photos etc when I wrote up the upgrade on my car. It may be of some use. See here:
JEC BB Index
Good luck
Paul
JEC BB Index
Good luck
Paul
Cheers,
FS[Western US]: XJ6 XJS Wheel Bearing Kits, Front, NEW, Never Used - $40
XJsc-guy
Apr 12, 2016 02:09 PM
FS[UnitedKingdom]: Set of 4 19" Propeller Alloy Wheels from Jaguar F-Type
PaulParanoia
Apr 12, 2016 05:42 AM
