Wheel bearing question
Old Jul 9, 2020 | 02:21 PM
petemohr's Avatar
Default Wheel bearing question
In the process of installing new brakes. Calipers, pads and rotors.
Everything is going smoothly but when adjusting the wheel bearings it never gets to the point where I feel resistance when turning the wheel.
There is no play, runout, or wiggle.
Is that an indication of worn bearings? They sound fine and roll smoothly off the car. They just never get to the point of resistance.
Old Jul 9, 2020 | 10:07 PM
baxtor's Avatar
Are the washers present directly under the nut?
only reason l can think of for not locking up is the nut running out of thread due to a spacing issue.
Old Jul 9, 2020 | 10:15 PM
Normal in my opinion.
If there is 100% NO wiggle as you say, then thats the point I always look for.
I have rarely had them tight enough to resist rotation, it just does NOT sit well with me.
Take it up to ZERO play, and then back off until there is JUST play, then back to zero. Do this a few times so YOU have a feel for it. When the zero is happy to YOU, leave it be.
Old Jul 10, 2020 | 04:53 AM
Had a CRAFT moment.
Recheck the bearing adjustment after 200 or so miles, always better to check than let them continue wrongly set.
They do settle, always, so dont forget.
Old Jul 10, 2020 | 06:09 AM
petemohr's Avatar
That's what I was thinking. Just wanted to make sure. Thanks for the reply.
wcourt3010
Sep 23, 2015 01:06 PM
sdettra
Jul 5, 2013 10:04 AM
Raheny
Mar 4, 2009 08:00 AM
