wheel fitment years
Old May 6, 2016 | 08:32 AM
fishbait1's Avatar
Default wheel fitment years
considering a 1996 XJS but I don't like the wheels ( bright chrome). will wheels from earlier years fit either 15" or 16". I like the 5 spoke brushed aluminum I have seen but don't know if they were an option for '96'
Old May 6, 2016 | 08:42 AM
Doug's Avatar
As far as bolt pattern and center hub dimensions go I'd say that any XJS wheel will work on any XJS. As will many wheels from other Jag models thru the mid-90s
cheers
Old May 6, 2016 | 10:09 AM
fishbait1's Avatar
thanks. I just was wondering. haven't got it yet. going to check it out today. only 22,000 miles but due to age may need bushings and hoses. any other things I should be concerned about?
Old May 6, 2016 | 10:21 AM
Padre's Avatar
Key thing to look for: bolt pattern of 5x4.75" (5x120.65mm), offset of about +28.5mm (+/-5mm is fine). 15" or 16" are available, with a width of usually 6" to 7". Also, hubsize is important if aftermarket. Should be at least 73.85mm.
Look on eBay for wheels for the XJS or XJ6 from about '88 to '96. I found a set of "Teardrop" wheels cheap that I intend to refurbish and give a try.
Padre
ericjansen
Aug 29, 2016 11:52 PM
HurQleys
May 2, 2016 01:25 PM
HurQleys
May 2, 2016 01:22 PM
F15DOC
Apr 28, 2016 11:33 AM
XJsc-guy
Apr 26, 2016 09:35 AM
