Widest rear tires on XJS
Old Apr 12, 2015 | 06:38 PM
Bc xj's Avatar
Default Widest rear tires on XJS
So I have an 86 XJS and I want wider rear tires. Im having my factory rims widened and I need to know how far to go. They can only add to inside of rims so I will need spacers as well. Id like 300s but I think thats pushing it a bit. I dont want to add fender flairs if possible.
Old Apr 13, 2015 | 03:46 PM
sidescrollin's Avatar
Not positive but I think the max in the rear stock is 245. I think 245/45r17
Not sure if 245 or 235 are easier to find or if one is a better option price-wise.
There are a couple of guys around here with aftermarket wheels and tires, hopefully they will chime in.
I've got 225/60 on wires, so this isn't really my department lol
Old Apr 13, 2015 | 04:37 PM
ronbros's Avatar
i dont think any thing wider than 245/255 will fit with factory wheel arches!
i have 295/35/18 rear tires and and had to wide body the rear flares about 4" each side(lot of work).
Attached Thumbnails Widest rear tires on XJS-r1-07368-023a.jpg   Widest rear tires on XJS-r1-07368-018a.jpg
Old Apr 13, 2015 | 09:42 PM
Bc xj's Avatar
Did you widen the whole rear panel, add flairs and cut the arches? Looks good.
I tried rolling the arches on my parts car with a bat. It worked good on my old Dodges but not so much on the XJS.
Old Apr 14, 2015 | 01:10 AM
Brake buster's Avatar
I am running 255/35/18 on the rear with zero issues ( XK8 Flute alloys )
225/40/18 on the front with a 25mm hubcentric spacer
BB
Old Apr 15, 2015 | 03:47 PM
DrScientist's Avatar
i've got 235/45-18s on the rear (XJR asteroids) there is a slight rub of the outboard side of the tire on the inside of the fender at full compression. but this may be due to the large-ish sidewall on these tires compared to what others run on 18 inch wheels.
also note, i believe there is a difference in the pre-facelift and facelift fenders, allowing for a wider tire in the facelift models.
mbergen
Oct 23, 2019 10:26 PM
KarimPA
Sep 12, 2015 08:15 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Corycarlo
Sep 5, 2015 11:41 AM
Joey T
Sep 3, 2015 05:31 PM
