wiper fluid reservoir
Old Apr 7, 2013 | 07:01 PM
macdoesit's Avatar
Banned
Default wiper fluid reservoir
Put wiper fluid in ran out under car, has anyone repaired or replaced reservoir?
Old Apr 8, 2013 | 10:16 AM
JagZilla's Avatar
It's an easy enough procedure. Simply remove the right front wheel so you can get to the panel directly in front of it. Once inside that panel, the reservoir is attached to the car by two easily accessible bolts at the top.
Old Apr 8, 2013 | 06:57 PM
JagZilla's Avatar
I stand corrected. I looked at my 89 donor when I got home from work. A large pozi-drive bit will remove the 2 screws that suspend the reservoir inside the fender well.
Old Apr 9, 2013 | 06:13 AM
alyary's Avatar
They are pretty easy to remove. Just a couple screws holding it in. Check the filler hose for a hole also it may not be the tank. Usually the tank gets damaged if the inner fender covers are missing. You do have to remove the tire to get to it though. I have a dozen of those bottles laying in the attic just in case. lol
kingdom worker
Nov 14, 2020 03:47 PM
Ferdie
Nov 26, 2018 05:42 AM
davidboger
Oct 1, 2015 10:13 AM
millertic
Sep 30, 2015 08:11 PM
