Wiper motor
Old Sep 17, 2019 | 04:19 PM
tedjan's Avatar
Default Wiper motor
Hi,
Can anyone recommend a source for a new or rebuilt or used wiper motor for my 1985 xjsc.It is Lucas 76314.
Thank you.
Old Sep 18, 2019 | 08:23 AM
Robert Laughton's Avatar
I have one, but it's out of the car and although I can make it run, it's hard to fully test all the functions to see if it all woks.
I have a matching plug cut from a dead car that I use to apply power to the motor, but I don't know what combinations are required to test all functions.
Anyone know how to bench test one?
Thanks,
Rob
Old Sep 30, 2019 | 01:20 PM
tedjan's Avatar
3 wires on motor where harness connects.Red is low speed(12 volt),yellow is high speed (12 volt) and blue is ground.Connect battery ground to blue wire,12 volt to red and you should have low speed.Then connect 12 volt to yellow and you should have high.
Old Oct 1, 2019 | 05:01 AM
Bez74's Avatar
If you do manage to find one - also get a plastic protector for it. The previous owner (x2) brought a 2nd hand wiper motor in June 2014 and did not install a new protector on.
The wiper motor cost $660 (Australian). When I pulled mine apart in Dec 2018, rust was starting to get in there again.
The protector cost me $40 from Jagdaim. Seems like $40 well spent
Below photo's were taken as I figured out how the protector fitted on
Old Oct 2, 2019 | 11:30 AM
tedjan's Avatar
Found rebuilt unit at East Coast Jaguar in Delaware.Very reasonable.
loftymk1
Jul 1, 2016 03:44 PM
e21pilot
Apr 26, 2014 11:30 AM
Invicta
Aug 1, 2012 07:56 PM
CatLovr
Dec 3, 2009 08:54 AM
ice-tray
Apr 21, 2009 03:25 PM
