Wire???
Old Apr 4, 2020 | 02:23 PM
Robbo D's Avatar
Default Wire???
Hi all.
I have been cleaning up my engine bay and have come across this wire the spade terminal isn’t connected to anything I can see. As you can see from the pictures the wire is near the air con compressor. Any ideas please.
Rob.
Old Apr 4, 2020 | 04:15 PM
Doug's Avatar
That connects to the a/c compressor. You should see the terminals immediately aft of the pulley/clutch assembly
Old Apr 4, 2020 | 11:37 PM
Dleit53's Avatar
Agree with the other Doug, it looks like it attaches to the AC compressor clutch.
Old Apr 5, 2020 | 01:46 AM
Greg in France's Avatar
I think it is part of a fuseable link system that somehow cuts the power to the compressor under certain conditions to prevent problems.
Old Apr 5, 2020 | 02:53 AM
Robbo D's Avatar
Thanks guys.
Greg my car is a 1991 pre face lift. I thought the fusible like was fitted to earlier cars and the later cars had a pressure switch in the air con system. I might be wrong and stand to be corrected.
Rob. This is my first XJS so it’s a learning curve.
Old Apr 5, 2020 | 04:58 AM
Originally Posted by Robbo D
Thanks guys.
You are probably correct. The plug looks like the one I used to have, and it certainly goes to the compressor, whatever it does when on there!
Old Apr 7, 2020 | 02:02 AM
Robbo D's Avatar
Found the terminals for the wires. The spade connectors are at the front of the compressor just behind the clutch. I didn’t see them before as the air con pipe was in the way. 😂
Thanks for all your help.
Rob.
gibbon
May 1, 2020 02:56 AM
zmoothg
Jul 23, 2017 06:31 PM
user 652867429824
Oct 16, 2015 12:32 AM
jhxj6
Feb 3, 2012 01:44 PM
Branman
May 30, 2009 04:19 PM
