XJ-S V12 Can I use UNLEADED
Old Nov 15, 2011 | 05:14 AM
edsmith's Avatar
Default XJ-S V12 Can I use UNLEADED
I am looking to buy an early GERMAN 1981 JAGUARE XJ-S V12 (pre-August 1981). QUESTION: Does this EARLY V12 have HARDENED VALVE SEATS so I can use UNLEADED as the V12 is NOT an HE ? Thanks; Ed
Old Nov 15, 2011 | 07:26 AM
Doug's Avatar
Yes, Ok to use unleaded.
Old Nov 16, 2011 | 04:35 AM
edsmith's Avatar
Default Jaguare xj-s v12 unleaded
Doug thank you for your reply regarding early 1981 XJ-S V12 using unleaded fuel.
Does that mean that the early 1981 V12 engines had hardened valve seats ?
All the best; Ed
DD[/quote]
Old Nov 16, 2011 | 07:03 AM
Doug's Avatar
Yes, hardened valve seats. Actually I've heard that all Jag engines have hardened valve seat, period. Don't know if that's true.
But, anyhow, I went to an early 80s Jaguar parts catalog that I have, which covers pre-HE V12s, and all variants, including USA/export variants, use the same valve seat. Since USA has had an unleaded fuel requirement since '74/'75.....
Old Nov 18, 2011 | 03:15 AM
Per's Avatar
Per
Correct, all V12s can use unleaded. European pre-HE must have 98, although I have used 95 when nothing else was available but then it is important to use a light foot and not with a heavily laden car. Top up with 98 asap, run down and then brim with 98 again.
Old Nov 18, 2011 | 07:41 AM
edsmith's Avatar
Thanks Per for your help regarding 1981 pre-HE XJ-S V12 using Unleaded.
All the best; Ed
Old Nov 18, 2011 | 07:49 AM
edsmith's Avatar
Thanks Doug for all your great help with my 1981 pre-HE XJS V12 using unleaded.
All the best; Ed
Old Nov 18, 2011 | 11:58 AM
Just as well. Leaded has not been available at the pumps in Europe for around 10 years or more.
Anyhow, I always thought that ANY vehicle equipped with Cats, must be run on unleaded.
Or does this vehicle year not have Cats?
Old Nov 19, 2011 | 04:53 AM
edsmith's Avatar
Hi Translator. No this 1981 (Pre-HE) XJ-S V12 does not have catalytic converters as it was first sold in GERMANY in 1981.
ALL THE BEST; Ed
Old Mar 18, 2012 | 12:56 PM
Pierre19's Avatar
With V12 engine, it's better to use unleaded 98 if the car is a non catalyst one.
Old Mar 18, 2012 | 01:58 PM
doo0T!doo0T!'s Avatar
If you are really worried there are products you can buy which condition the fuel with additives which replicate what lead used to do. Fuelstar is one of them, I have two on my '74 XJ12
sadepol01
16
Nov 22, 2024 05:05 PM
SCMike
Nov 25, 2015 07:55 AM
marklcap
Sep 29, 2015 12:41 PM
redgear
Sep 26, 2015 07:21 AM
