XJS 1992 RHD ZF Steering?
Old Nov 15, 2020 | 03:03 AM
CharlesHK's Avatar
Default XJS 1992 RHD ZF Steering?
Greetings everyone,
Does anyone know when ZF steering was first used on RHD XJ S?
Thank you,
Charles
Old Nov 16, 2020 | 10:22 AM
equiprx's Avatar
Are you sure that your using the 'ZF' designation correctly?
I've never seen it used on anything but transmissions.
If so, it won't be the first thing I learned today.
Old Nov 16, 2020 | 10:58 AM
Greg in France's Avatar
Yes, ZF make steering racks and they were on all facelift XJSs apart from maybe a few as the old Adwest racks (which were used throughout the XJ and XJS range hitherto) were used up. Their main characteristic is that they are slightly less assisted and provide noticeably more road feel than the Adwest racks do.
If you want to know if your car has one, get under it and look at the rack. The ZF rack body is an entirely aluminium casting (Adwest a steel tube) and the ZF logo, a ZF in a circle about 1/2 an inch in diameter, is cast into the rack body.
A LHD ZF steering rack for an XJS
Old Nov 16, 2020 | 01:30 PM
Mac Allan's Avatar
Can a ZF Rack be fitted to a pre-facelift XJ-S?
Old Nov 16, 2020 | 03:21 PM
Straight bolt-in replacement; but you will need new pipes from the pump.
bergstrom30
Feb 24, 2018 08:19 AM
HypnoGuru
May 24, 2017 01:58 PM
thocar
May 14, 2017 01:59 AM
