XJS HE V12 1985 Cuts out after 5 seconds
Old Jan 5, 2014 | 10:09 AM
chrisainley's Avatar
Default XJS HE V12 1985 Cuts out after 5 seconds
Car starts and runs smoothly for a few seconds then cuts out abruptly. Will do just the same immediately afterwards. I suspect ignition electronics but ECU has been replaced with no effect. Problem just appeared after car was un-used for 4 months. Any advice or offers to fix it close to Milton Keynes Aylesbury or Oxford.
Old Jan 5, 2014 | 11:12 AM
Doug's Avatar
Does this happen only with a warm engine? Only with a cold engine?
Besides the ECU has anything else been checked or replaced?
There are many possibilties here.
From what you've said so far, and on the notion of "you gotta start somewhere", my gut feeling is the the fuel pump is not operating once the key is released from the "start" position. The engine runs for a few seconds on the fuel that was provided when the engine was being cranked but then dies from fuel starvation a few seconds later.
Ground the orange wire to the fuel pump relay. The pump should now run whenever the key is "on". Now start the engine and see if it stays running.
Post back if details needed.
PS- "ignition electronics" and "ECU" are really two different things with a bit of overlap. The ignition system will operate without the ECU. But the ECU will not operate properly without a properly functioning ignition.
Old Jan 5, 2014 | 11:33 AM
Lightbulb Thankyou Doug
Also changed engine-temperature-sensor. Can't check it when warm because it cuts out after seconds. I had assumed that if it was a fuel issue, it would have spluttered rather than stopping abruptly, but I will certainly follow up on the suggested fuel pump relay check.
My suspicion relating to the ignition switch electronics was because, at the same time as this problem occured, the audio amplifier stopped working.
Old Jan 5, 2014 | 11:45 AM
Doug's Avatar
Run a jumper wire from a 12v source to the "+" post of the ignition coil. See if the engine stays running.
Post back if you need help with a good 12v source in the engine bay
Old Jan 6, 2014 | 03:52 AM
Default Many thanks Doug
I will apply your suggestions, and let you know the result. It may be a few days before I get the opportunity. Your help is much appreciated.
1100me
Jul 24, 2023 06:10 PM
Daim
Nov 28, 2016 09:28 AM
redrover41
23
Sep 25, 2015 01:33 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
