XJS rear shocks
Old Aug 13, 2025 | 04:46 AM
Asdrewq's Avatar
I have to respectfully disagree. Bilsteins are far stiffer than the OEM shocks. Boge shocks are still available and they are the OEM ones. Also, I believe adjustable shocks are an excellent choice. Either Gaz or AVOs work well and you can adjust them to your exact preference.
I fitted the GAZ adjustable platform shocks and am very happy with them. I got the black versions from Martin Robey in the UK (Jag specialist, mostly E-type), pre-installed with new aftermarket XJS springs.
They have damping adjustment which isn't ideally suited to the road but good enough:
On the rotary dial, 1 click from softest is...very soft, about the same as totally worn out OEM. You can easily bounce the rear of the car by pushing on the boot.
I have them set at 4-6 clicks from soft, which i'd say is slightly stiffer than OEM but quite comparable and still retains a nice ride. The adjustment range between 1-6 clicks makes quite a lot of difference.
They go all the way up to 20 clicks but anything over 8 or so is what i'd describe as extremely stiff and kindof pointless for road use.
Old Aug 13, 2025 | 03:35 PM
jerry_hoback's Avatar
Ok sorry. I go away now.
92/93 XJS
Jan 31, 2022 05:51 PM
steveq
May 27, 2020 04:59 PM
jordanmc
Oct 17, 2017 03:37 PM
jaguarjoe470
Jul 21, 2015 11:16 AM
SouthernGypsy
Mar 25, 2015 10:05 AM
