xjs ride quality
Old Mar 31, 2014 | 07:20 AM
joeconsidine's Avatar
Default xjs ride quality
I have a 1996 celebration xjs 4 litre coupe it has done 63,000 miles. i have never been particualrly happy with the ride quality it is too harsh. Can this be improved by fitting new original or different shock absorber etc ?
Old Mar 31, 2014 | 08:14 AM
RonaldP's Avatar
Do you have the sport pack option? Has the suspension system been altered by any previous owners? If so take it back to original bushings and shocks. Most owners would agree that the steering rack and the sway bars would benefit from Poly bushings, but all else should remain with stock bushings.
Old Mar 31, 2014 | 08:46 AM
Thanks for your commnet
Old Mar 31, 2014 | 08:53 AM
Greg in France's Avatar
A set of OEM Boge shocks all round is the place to start. After that it may be your springs are too hard, but I doubt it. I once put a set of monroes on my car and it ruined the ride completely: it was like no suspension at all. They came off the next day!
Greg
Old Mar 31, 2014 | 09:54 AM
AllanG's Avatar
As I recall, all 4 litre coupes had the sports suspension as standard. Easy check, look at your shock absorbers. Green coloured shocks will indicate sports set up. The front springs are significantly stiffer (43%) and the shocks are too. The black Boge shocks are significantly more compliant though some find them too soft.
Old Mar 31, 2014 | 03:43 PM
RonaldP's Avatar
I thought all sport packs came with the rear sway bar. My 4.0 coupe does not have the sway bar nor does it have the body reinforcing mount with the bolts for the "U" straps.
Old Mar 31, 2014 | 04:23 PM
AllanG's Avatar
The rear anti-roll bar appeared and disappeared from the XJS at various times throughout it's production. I'm not sure when the final change was made but certainly all SportsPack equipped cars from 94 to 96 did not have a rear bar nor was one available as an option from the factory.
Old Apr 1, 2014 | 07:15 PM
Mkii250's Avatar
My '92 coupe has the rear bar with black shocks. Maybe there's some randomness in the specs. I couldn't ask for a better ride and I really do think the handling is excellent.
Wolfy
May 28, 2024 08:06 AM
Forcedair1
Feb 19, 2020 01:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
02jagstype
Sep 4, 2015 08:20 PM
