xjs shocks
Old May 26, 2020 | 12:00 PM
steveq's Avatar
Default xjs shocks
1994 xjs 6 cyl auto...............suggestions for best brand of shocks to replace old ones............no stiffer or softer just the best OEM brand ............thanks
Old May 26, 2020 | 02:03 PM
Greg in France's Avatar
Boge are the OEM brand. Quite reasonably priced and will give OEM ride and handling.
https://www.welshent.com/Jaguar-Shoc...oge-P1886.aspx
Old May 26, 2020 | 02:19 PM
VancouverXJ6's Avatar
KYB Grey shocks for better responsiveness and less yatch handling
Old May 26, 2020 | 03:34 PM
Rescue119's Avatar
mine just showed up today!
Old May 27, 2020 | 11:26 AM
Rescue119's Avatar
Did you use the factory springs? I'm trying to figure out what parts besides the 4 small bushings for the top holes to keep when i take then to the shop to get the spring off.
Old May 27, 2020 | 02:40 PM
I run factory springs seens ok, one day ill get the uprated ones from simplyperformance.
you can also get poly shock bushings for added firmness
Old May 27, 2020 | 03:02 PM
Rescue119's Avatar
Did u save any of the hardware from when you took the springs off the shocks though?
Old May 27, 2020 | 03:39 PM
Hedman's Avatar
I recently replaced the rear springs and shocks with Boges that I bought from Welsh Enterprises.
The old assembly had spacers at the bottom of the spring where it engages the shock (circled in red below).
On the new shocks, the indent that traps the ring that holds the spring in place looked like it was higher up on the shock (circled in yellow). So I assembled the unit without the spacers and confirmed that the length of the spring “at rest” in the shock was the same as with the originals.
Note that there are spacers in the top mount of the shocks where they attach to the cage that are not included in the kit from Welsh. So I re-used these off the old shocks.
Hope this helps.
Old May 27, 2020 | 04:41 PM
Rescue119's Avatar
Hope this helps.
well different shocks but kinda an idea still ill take some measurements of the old ones at rest as well. I mocked up the new ones with the included hardware and its pretty damn close. But the old ones are still under pressure. I'm suprised
I can't find anything about the install of these kyb shocks. People have installed them but don't mention if any of the old hardware is used except for the small insert that goes in the top eye
Old May 27, 2020 | 04:59 PM
Rescue119's Avatar
from the looks of this I wont need anything but the springs and those spacers
petemohr
Mar 13, 2021 03:34 PM
jordanmc
Oct 17, 2017 03:37 PM
NCJagman
Mar 25, 2016 12:58 AM
jaguarjoe470
Jul 21, 2015 11:16 AM
SouthernGypsy
Mar 25, 2015 10:05 AM
