XJS Transmission pan and oil cooler
Old Mar 17, 2015 | 09:41 PM
d a's Avatar
d a
Default XJS Transmission pan and oil cooler
Does anyone have a good part number for an aftermarket oversized transmission pan and oil cooler that fits and works well on the 1994 xjs v12?
Don
Old Mar 17, 2015 | 10:26 PM
86jag's Avatar
It has a 4l80e transmission, so there should be good aftermarket support for the larger pan. However if I recall correctly the stock pan is already a high volume pan. I believe GM made two different sizes.
The trans cooler, you can purchase one and mount it inline with the current cooler in the radiator. just pick the one you want based on size, brand, etc. You will have to modify the hose fittings to work with whichever one you pick.
Old Mar 18, 2015 | 04:35 AM
baxtor's Avatar
Jaguar used a unique pan. Pan and gasket will not interchange with the GM model.
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
Dymaxxion
Sep 4, 2015 02:40 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
