XJS is very low
Old May 18, 2021 | 10:51 AM
pimmow's Avatar
Default XJS is very low
Hi i have a '95 xjs 4.0 which in my opinion is too low to the ground. i really have to brake hard before i run over a speed bump, its a bit embarrassing actually. i wonder which suspension struts it needs, if i would want to replace them. i think somebody put some lowered struts on it in the past. any model numbers???
thanx, pim
Old May 18, 2021 | 11:02 AM
Vee's Avatar
Vee
It won't be the struts (or shocks in your case), it will be the springs.
What sized tires are you using?
The XJS, especially the facelift with that front spoiler is indeed low.
If you take a measurement at each of the wheel wells, measuring the distance between the ground and the bottom of the highest lip on the wheel well (ground - past the wheel center cap to the underside of the fender's wheel arch), perhaps we can tell you if something is unusually low?
Old May 18, 2021 | 04:31 PM
Thermo's Avatar
Veteran: Navy
pimmow, like was said, odds are, after 25 years of sitting on the springs, the springs have sagged a little bit and now the car rides say an inch lower than it did when stock. The fix is getting new springs on all 4 corners.
Old May 18, 2021 | 05:08 PM
I've moved your question from General Tech Help to XJS forum. This is the place to post technical questions about your model.
Old May 19, 2021 | 01:40 AM
pimmow's Avatar
Hi Vee, thanx for your reply, the height of the wheel arches are 65 cm, and I'm using 225/60r16 tires...
looks cool like this but I don't like all these people laughing at me when I hit a speed
bump again...
thanx!
Old May 19, 2021 | 03:38 AM
Greg in France's Avatar
65cm = 25 inches. Correct height.
Old May 19, 2021 | 05:17 AM
kansanbrit's Avatar
If you are hitting the brakes hard you are making the front even lower. If you shocks are bad it can go down a long way.
Old May 19, 2021 | 05:19 AM
Spikepaga's Avatar
Correct height.
I was once told at a mechanic shop I went to the first time for a quick oil change a couple of years ago that my car was “lowered” . I immediately left since he he clearly had never seen what an XJS looked like ever in his life.
Old May 19, 2021 | 05:35 AM
Keesh's Avatar
The facelift is 2 cm lower than its predecessor, namely 12 cm ground clearance.
Old May 19, 2021 | 07:07 AM
garethashenden's Avatar
I may be mistaken, but isn’t the whole point of a speed bump to make you slow down? Slow down gradually and give everyone time to admire the car.
Old May 22, 2021 | 06:51 AM
leep123's Avatar
Hi Pim,
As said the facelift is lower but yours looks about right to me.
For comparison, my 1990 pre-facelift had a broken front coil spring. Front ride height prior to replacement was 25.75 inches (OS - broken spring) and 26.5 inches (NS). On replacement of both springs OS was 26.75 inches and NS was 27.25 inches. That was 4 years ago and the shop said they would settle a little with time.
The break in the spring was near the top and could only just be seen with the car jacked up and wheels hanging so if you get a significant height difference each side check the springs.
Speed bumps - I hate them. Several of the ones near me in 30 MPH limits have to be driven over at 10 in any of my cars to prevent damage. People with 4x4s and company cars drive over at 30+ because they don't care. More speed cameras and less speed bumps is what we need.
Cheers,
LeeP
Old May 22, 2021 | 06:58 AM
pimmow's Avatar
Hi leep, thanx for your answer. My tyres were changed last year; and I noticed them being less high now, although they had the same sizes mentioned on them. When I made a slow sharp curve with the old ones; I could hear them scrape something in the back wheel arch. I think the last owner also didn't like speed bumps so he put the largest size tyres on them. I liked that more also.I would indeed like it to be a tad higher from the ground. But I think all springs are good so I'll have to live with it I guess.
Old May 22, 2021 | 11:42 AM
Geewhite's Avatar
Maybe this shows the rear end height?
I think I may have a height issue.
Not Hi-Jacking a thread, just throwing my tuppence worth in for my benefit.
1983 HE.
Front: Height from arch to ground 25 1/4 inch
Rear: Height from arch to ground 23 3/4 inch.
I have always thought the rear was too low, it bottoms out when it shouldn't. Gaz shocks (me no likey) are either too firm or too soft, no happy medium for my liking.
But if the springs are the wrong ones fitted (or lowered springs), then the ride height would be much lower.
Been told they were not lowered intentionally and were OEM spec.
(I bought a new phone, I have let it drain down, now recharging it or I would pop out and take a pic of the gap between the tyre and the wing. ( I hear you, use a camera..duh!))
This I will edit tomorrow with a picture for your perusal and opinion.
Cheers.
Ps, Night off tonight. Myself and Stella are being acquainted again. Stella Artois.
Old May 22, 2021 | 04:31 PM
leep123's Avatar
Hi Geewhite,
Beautiful looking car - at any elevation.
Mine had new rear springs about 8 years ago. Will measure up height tomorrow and let you know for comparison.
Hope Stella treats you kindly tonight!
Cheers,
LeeP
Old May 22, 2021 | 06:46 PM
Pirk's Avatar
For comparison on my 89,
Fronts are a little high at 67cm/26.5 inches.
Rear is good at 65cm/25.5 inches.
When I replaced the front shocks with Bilsteins, I left the spacers. Once I get in there and drop the springs again, ugggghhhhhhh, I remove the spacers and all will be good.
Old May 22, 2021 | 07:21 PM
ptjs1's Avatar
pimmow,
It's difficult to see but I think the car is running fractionally low at the front. The ground clearance on a late facelift XJS at Gross Vehicle Weight is 123mm. Your measure seems slightly lower than that.
Another measure is how much clearance you have between the top of the tyre and the lip of the wheelarch. With 225/60 tyres and springs and shocks in good condition, you should get 2-3 fingers when measure in a direct horizontal plane.
Paul
Old May 23, 2021 | 12:48 AM
pimmow's Avatar
Thanx Paul; I will measure that again; in the meantime some more pictures of her...
isn't she beautiful
thanx
Old May 23, 2021 | 08:21 AM
Brewtech's Avatar
Mine is low too, and its due to worn subframe bushings. Look to see if theyre shot. If they are, theres your problem.
Old May 23, 2021 | 09:07 AM
Geewhite's Avatar
Originally Posted by leep123
Hi Geewhite,
Cheers,
LeeP
Thank you LeeP.
Stella was kind,
I start at 15.00 and finish at 20.00. Then eat.
Only at the weekends.
Very rarely suffer.
Graeme
Old May 23, 2021 | 10:37 AM
leep123's Avatar
Hi all,
Checked mine after standing all night (car not me!).
I get very similar figures to Pirk:
Front 26.25 inches (OS); 26.5 inches (NS) - 4 year old springs.
Rear 25.25 inches (OS); 25.5 inches (NS) - 8 (approx) year old springs.
That is for a 1990, 3.6 coupe (pre facelift). Interesting that nearside is 1/4 inch higher. I think I read somewhere that Jag set the cars up to be slightly higher on NS to offset the UK road camber and keep car level although this may all be just a coincidence in my case.
Cheers,
LeeP
XKR8
May 6, 2016 03:45 PM
Jaguar Forums Editor
Jaguar Press release
Feb 16, 2016 06:18 PM
pirat3120
Oct 18, 2013 07:29 PM
svldvc
Feb 12, 2011 01:46 AM
