Yet another "What is it"
Old Aug 27, 2019 | 04:18 PM
petemohr's Avatar
Default Yet another "What is it"
'96 4.0 Convertable.
Back right side of trunk/boot. Antenna removed.
A=Connector with a jumper wire
B=Empty connector
C=?
Old Aug 27, 2019 | 08:40 PM
carsnplanes's Avatar
"C" should be the "Bulb Failure Module" for that side. Monitors failed bulbs and lights a message light on dash. There are four. One for each corner of the car.
"A" and "B", I'm not sure of.
Old Aug 27, 2019 | 08:45 PM
One of those plugs may go to the security module which is that black box tucked in the corner under the light connectors. Does your security system key fob work?
Old Aug 28, 2019 | 06:17 AM
petemohr's Avatar
Originally Posted by carsnplanes
"C" should be the "Bulb Failure Module" for that side. Monitors failed bulbs and lights a message light on dash. There are four. One for each corner of the car..
That's what it is. Thanks.
Old Aug 28, 2019 | 06:20 AM
petemohr's Avatar
[One of those plugs may go to the security module which is that black box tucked in the corner under the light connectors. Does your security system key fob work?[/QUOTE]
Thanks for the reply. I know where the go. I don't know what they are for.
I looked at the Electrical Guide but didn't find anything helpful.
Old Aug 28, 2019 | 06:36 AM
Spikepaga's Avatar
I am quite certain none of those go to the security module. The car would be unable to come of with the security module disconnected, plus yours looks safely in place.
I believe B is for the antenna override relay/ diode for cars fitted with the spoiler
Old Aug 28, 2019 | 09:11 AM
petemohr's Avatar
That's it. One wire goes to the antenna motor so it makes sense.
2 down 1 to go!
Old Aug 28, 2019 | 10:01 AM
Spikepaga's Avatar
2 down 1 to go!
Pete, I just looked in my car and A looks exactly that same. It’s just a factory thing. It very likely is a connector for cars with mobile phones installed
DavidN
May 26, 2021 12:49 PM
SteveJacks
Aug 28, 2020 01:09 PM
Barry_Tucker
Apr 30, 2019 10:38 AM
4zfed
Feb 19, 2019 08:56 AM
97Aggie
Aug 9, 2009 05:08 PM
