ZF steering rack rebuild - have I f**ked up?
Old May 25, 2024 | 06:24 AM
fried_hippies's Avatar
Question ZF steering rack rebuild - have I f**ked up?
I HAVE A WORKSHOP AGAIN! Car is in paint and looks great, I have boxes of bits that I need to bolt onto it.
My rack is cast with "ZF", "7852 218", "289920" and the purple tag says "7852 974 224" and "CCC 6012". It's an RHD ZF rack. I'm following the guide at https://www.jaguarforums.com/forum/a...0-zf-servo.pdf
part numbers - 1994 XJS ZF rack 7852 974 224
I've got the valve housing and the inner tie rods off. I'm stuck on what I think is the preload adjuster. I have lightly drilled out where it was peened, but the bolt does not want to rotate. It'll go about 30 degrees either way, then the resistance increases. In fact, I've rounded the nut :-(
Do I need to drill the peening out more? Should this in fact screw off?
pre-load adjuster - 1994 XJS ZF rack 7852 974 224
Also, how TF are you supposed to remove this blanking plate?
blanking plug for bottom end of input stub shaft - 1994 XJS ZF rack 7852 974 224
Old Jun 12, 2024 | 09:52 PM
BigWeld56's Avatar
Hey, wish I could help out here but I haven't gotten to this part yet.
Best of luck!
Old Jun 13, 2024 | 12:53 AM
Greg in France's Avatar
Error post
outsidecenter
May 7, 2024 01:32 AM
N Bath
Apr 15, 2022 12:25 AM
scottpeterd
Feb 5, 2020 12:08 PM
XJsc-guy
Jan 18, 2019 09:06 AM
anjum
Feb 22, 2013 07:14 AM
