‘08 XKR Parking Brake fault
Old Jan 16, 2019 | 11:05 AM
‘Oleguy's Avatar
Default ‘08 XKR Parking Brake fault
I have the Alcon brake package that I just completely overhauled. 4 new rotor, new Porterfield RS-4 pads, Alcon shop rebuild of calipers. Since I was installing new rotors I removed the Parking Brake and pads which I then turned the piston back fully with a piston tool (bent needle nose).
Everything went well and all new fluid after reservoir was drained using turkey baster. Bleed calipers, both bleeders many times than actually needed as I wanted the old out. But when I went to apply the Emergency / Parking Brake I received a ‘fault’ light on my dash. ‘Parking brake cannot engage’ at this time.
How do I get my parking brake to work?
Thanks in advance!
Old Jan 16, 2019 | 11:38 AM
Ranchero50's Avatar
There's a trick to this. I'm pretty sure it's in the free service manual but it's been a while since I looked it up (had the same problem)
Old Jan 16, 2019 | 11:53 AM
Sean W's Avatar
Assuming assembly was done correctly, here's the procedure for calibrating the parking brake:
Parking Brake Calibration
The parking brake system must be calibrated whenever the battery has been disconnected or has been in a state of discharge, or repairs have been carried out to the rear service or parking brake system.
NOTE:
If new rear brake pads have been installed, pressure must be applied to the brake pedal a minimum of five times prior to calibration of the parking brake system.
To calibrate the parking brake system:
1 . Place gear selector lever in 'P' Park position.
2 . Release parking brake cable tension to service position. Parking Brake Cable Tension Release
3 . Set the ignition status to 'ON'.
4 . Apply and hold the footbrake then pull up the parking brake switch.
5 . To release the parking brake, apply and hold the footbrake then release and press down the parking brake switch.
Old Jan 16, 2019 | 01:28 PM
gkubrak's Avatar
I recently replaced the rear alcon rotors as well. I left the old e-brake pads in there, but due to the thicker rotor, I had to turn the piston back in a bit - not all the way. I basically just turned it in until the gap between the rotor and pads matched what it was before. Took a few iterations of removing the rotor and half the e-brake caliper, but I think it worked out. Won't know till i start the car later this week.
Speaking of the brembo e-brake caliper .... does anyone know where I can get the anti-rattle shim?? Dealer tells me its PN C2C31196 but they want like $200+ for it. Where else can I find this cheap piece of metal?? If i can't find one I will probably just cut and bend one out of sheet metal myself.
Old Jan 16, 2019 | 05:36 PM
Ranchero50's Avatar
What Sean said. Strange I forgot that I just unhooked the battery after doing the work. Oldtimers already???
Old Jan 16, 2019 | 08:15 PM
‘Oleguy's Avatar
NOTE:
Sean,
I never did disconnect the battery. I just split the EPB caliper to turn in the piston and dismounted it to remove the rotor. Reinstalled in reverse order on the new rotor.
I did install everything correctly. Only issue is parking break fault.
So if I understand this correctly, I need to disconnect battery for a minute. Reconnect then perform the procedure you stated.
Is this correct?
Thanks!
Old Jan 16, 2019 | 08:24 PM
Sean W's Avatar
Sorry, to clarify, this is the procedure from the service manual. I don't think you need to disconnect the battery, just that you need to follow the calibration procedure if you disconnect the battery or service the brakes.
Old Jan 16, 2019 | 09:45 PM
‘Oleguy's Avatar
Default Success !
I followed the procedure as you had described. I did have to do it 6x I assume to ratchet the piston on parking brake caliper to where it had sufficient tension for a sensor could read before I recieved Parking ‘Brake’ light on display.
You can hear this process in a quiet garage.
Thank you Sean and Ranchero
Old Jan 17, 2019 | 06:00 PM
Sean W's Avatar
Glad it worked out!
Old Jan 18, 2019 | 08:00 AM
Brutal's Avatar
you can set this fault when you turn in so far that the park brake motor sensor too much travel and will see this as a fault and set the warning. I usually pull up a little quickly on the park brake switch and then back down so it doesn't travel but a little bit. Then do again till you get it fully set. I you set the light do a hard reset on the battery so it says "set parking brake" again and repeat.
ford289ci
62
Sep 28, 2015 08:37 AM
45Wheelgun
Oct 5, 2011 03:44 PM
bodytech
Mar 9, 2011 07:59 AM
