2001 xkr led dash and other led replacing
Old Jan 25, 2014 | 03:00 PM
john47's Avatar
Default 2001 xkr led dash and other led replacing
I've been pondering the replacement of existing bulbs with led lamps and I have found ones that work great. The company on line is Super Bright LED's,Inc.
If you call them, they are quite knowlegable. Here is what I have replaced.
1. 4 main dash bulbs are 194's- replacing leds are- WLED-CW6:cool white. They are the main bulbs for backlighting. works great, a lot of light. 6 front facing leds on each bulb.$3.74 each.
2. 4 additional bulbs on same display are mini 194's. They support each directional light, the odometer and high beam light. replacing led s are
74-WHP: cool white. $2.49 each.
3. 2 Map lights are 194's- replacing leds are WLED15TAC:cool white.$6.95 each. they have15 small leds on each, they are cylinder shaped, lights around and at tip, super change. Work great.
4. The balance I replaced where 194's-2 rear license plate, 2 floor courtesy, using the WLED-CW6's
Hope this helps someone.
There is video on how to get dash out and other's by rev sam. They are a great help.
John47
Monkeyhanger
Dec 17, 2018 11:23 AM
revauto
Nov 18, 2016 08:02 AM
GordoCatCar
Oct 20, 2011 06:46 PM
m0t0rm0uth
Interior
Nov 10, 2009 01:01 PM
