2007 antenna
Old Sep 4, 2009 | 12:36 AM
rtmyers1's Avatar
Default 2007 antenna
anyone know how to remove the cover around the outside of the power antenna. i bought a new mast but not sure how to remove the cover to get to the bolt without causing any damage..... thanks
Old Feb 23, 2014 | 02:54 PM
Qwikkitty's Avatar
Wondering the same thing before I break it?!
Old Feb 23, 2014 | 06:56 PM
Qwikkitty's Avatar
I figured it out as I just replaced the mast on mine. I'm doing a HOW TO write up on it so watch for it. The bottom of the plastic cover is a rubber grommet that fits to the hole in the body. So, just gently twist and wiggle it up and out and then pull it up and off the antenna. I used some plastic interior panel removal tools that helped with this process that I purchased at Harbor Freight. Watch for my post on the entire process to replace the mast, with photos.
oldjaglover
Dec 25, 2024 04:33 PM
philwarner
Jan 31, 2016 09:36 AM
Sonnyblack
Oct 4, 2015 05:42 PM
Ragn0r
Sep 29, 2015 10:38 AM
Ragn0r
Sep 28, 2015 06:14 PM
