2007 Jaguar XK dashboard went blank and car won't start
Old May 15, 2017 | 06:03 PM
Mobetter18's Avatar
Default 2007 Jaguar XK dashboard went blank and car won't start
I was driving my car and the dashboard went dark. My gauges are stuck. I tried disconnecting the battery post but nothing. Windshield wipers not working, windows. Do anyone know the problem
Old May 15, 2017 | 06:29 PM
Welcome to the forum Mobetter18,
I've copied this question from your Intro to X150 forum. Members here with the same model will be able to help.
Old May 15, 2017 | 06:38 PM
Cee Jay's Avatar
Nearly EVERY electrical problem with these cars is battery related. Can/did you check the battery voltage? It should be 12.6 or so to have close to a good battery. If not, why did the battery go flat? Merely an old and worn out battery? Check the date on it. Also, bring the battery to an Auto Parts store, most do a battery check for free, but usually you'll need to put it on a charger for 24 hours beforehand. Not a "maintainer" or "trickle charger", but an actual battery charger.
If your battery checks good, then there is probably a problem with the alternator/charging system.
Old May 15, 2017 | 08:39 PM
Ranchero50's Avatar
I'd also suggest just pulling the battery out and taking it for a test. Mine held 12.8 vdc but failed under the slightest load. A battery tender has been keeping it alive until my replacement shows up.
Old May 15, 2017 | 08:46 PM
davchr's Avatar
Did the motor stop running when the gauges went blank?
is EVERYTHING on the car dead now? No interior lights or headlights?
andrew2110
Apr 23, 2016 07:14 AM
iriddles
Oct 12, 2015 05:36 PM
jagger
Oct 12, 2015 07:31 AM
rdr
Feb 19, 2011 10:25 PM
