2007 XK help with starting
Old Mar 20, 2025 | 03:44 PM
RBing's Avatar
Default 2007 XK help with starting
My 07XK is giving me problems. It's more than likely self inflicted but it's still a problem. I was changing out my upper control arm on the drivers side and moved some of the boxes in the attached photo so I could reach the nut. After I got it changed out, my car would start intermittently. I couldn't figure it out and then remembered I moved the fuse box and the little box above it around. I would jiggle those and tighten them and then the XK would start. Well now, nothing. The car lights up and when I crank it I hear a ticking sound but nothing. Anybody have any clues on what I should check?
Old Mar 20, 2025 | 05:09 PM
NBCat's Avatar
Start with verifying available voltage. Use a voltmeter across the battery terminals to read the available voltage with the ignition in the OFF position. There should be a minimum of 12.6 volts for all the modules to function properly. If the voltmeter shows less than 12.6 volts, charge the battery for five hours at 2 to 5 amps and retest.
Once you verify the available voltage, check the connections on any of the wire looms you moved.
Old Mar 21, 2025 | 12:08 PM
RBing's Avatar
NBCat, I have 12.6 on the battery. I checked but can't see any loose wires. Can I check the continuity of each fuse to see if something isn't connected properly? Do you know which fuse controls my starter?
Old Mar 21, 2025 | 12:19 PM
NBCat's Avatar
Here is a link to the Electrical section of the X150 Workshop Manual:
https://www.dropbox.com/scl/fi/09n66...=1uygnrxj&dl=0
The starter is controlled by a relay and the brake pedal switch. Sometimes one must press down very hard on the brake pedal to engage the starter motor.
Old Mar 22, 2025 | 09:08 AM
Stuart S's Avatar
Try this: Press the START button before you put your foot on the brake pedal. It should start right up.
You might have inadvertently stepped on the brake pedal multiple times while sitting in the car before trying to start it. "Pumping the brakes" will cause the pedal to be high, and you may need to step on it with all your strength and use both feet to close the starter switch as @NBCat explained.
Old Mar 22, 2025 | 09:08 PM
RBing's Avatar
Stuart, that didn't work. I'm pretty sure I did something with that box. It was starting intermittently and I would wiggle the box and then it completely stopped. I can't figure out how I can test the relay or fuse when I push the start button to see if it's getting power.
Old Mar 23, 2025 | 08:47 AM
Stuart S's Avatar
@RBing I noted that your Public Profile shows that you have a 2003 S-Type , that you recently joined the Forum, and don't have a Signature.
Please read this and create a signature that includes details of your car and location so we don't have to keep asking you about it. See my signature at the bottom of this page. It's automatic at the end of my posts
New Members Introduction - A Must Read
I understand your need for privacy. Your details don't have to be specific, but your country, model year and body style are important.
Sampson
Feb 21, 2023 09:27 PM
peterv8
E-Pace
Jan 5, 2023 03:03 AM
mosesbotbol
Jan 27, 2022 03:22 PM
Cee Jay
Nov 23, 2021 07:27 PM
robbing
Oct 1, 2015 11:24 AM
