2007 XK Reverse lights (inner) Help
Old Jun 12, 2019 | 06:14 PM
kj07xk's Avatar
Originally Posted by Flynnstone
They all appear to be left inners. Not the prized right inner. ☹️
Well dang, you're correct.
Old Jun 13, 2019 | 12:03 PM
sov211's Avatar
I’ve order the correct one from the local jag dealer. Not cheap, but I’m in a tight time line to get car approved.
Can you clarify why the fact that your car has just one reverse light (regardless of which side it is on) is an issue for the provincial approval? Or is the situation the following: with the transmission in reverse the fog lamp (rather than the white reverse lamp) comes on? Your car legally needs just one white reverse lamp. It does not need any rear fog guard.
and if the rear light clusters on your car are reversed ( that is, the white and red fog lamps are reversed) would that lead you to suspect that at some point there was accident damage to the rear and the wrong units were installed?
Old Jun 20, 2019 | 11:06 AM
Flynnstone's Avatar
One reverse lamp is fine for provincial approval.
It just needs to be white.
Also, both were Red. Somehow a UK fog lamp was installed on car.
This is now fixed.
The only pain I have now is to get the window tint adhesive off the windows. Argh.
Old Jun 20, 2019 | 11:25 AM
Cee Jay's Avatar
For the adhesive, carburetor cleaner works fantastic, on a soft scrubby pad. Takes not much time and little mess. Just be careful to not get any on other surfaces.
cdre
Jul 24, 2017 05:33 PM
nickxj6
Mar 18, 2015 05:34 PM
Alphawolf
Sep 14, 2014 01:08 AM
daboss085
Nov 1, 2012 05:13 PM
