2007 xk speaker wiring code
Old Oct 11, 2014 | 05:45 PM
local38's Avatar
Default 2007 xk speaker wiring code
hi, I am trying to add a amp to my 07 xk with standard alpine stereo I found a sub woofer and I want to add a new amp . does any one know the speaker color codes. I found the speaker connector under the passenger right lower kick panel . when I unplug this all the speakers go dead so I know this is the main junction plug for the speakers I just don't know color codes for right,left.front ,rear ect.
Old Oct 11, 2014 | 07:32 PM
u102768's Avatar
I don't know if the colours are reversed for LH/RH drive but:
Front Driver = White/Blue and Yellow
Front Pass = White/Green and Red/White
LH Rear = White/Blue and Yellow/Blue
RH Rear = White/Green and Yellow/Red
Old Oct 13, 2014 | 09:49 AM
local38's Avatar
Thank you that's a great help. You wouldn't happen to know pos.+ and neg. - on these colors by any chance ? for example is White/Blue +and Yellow - to Front Driver Door ?
Old Oct 13, 2014 | 06:52 PM
u102768's Avatar
The first colour combination listed for each is positive. The second one is the negative.
e.g.
Front Driver = White/Blue (+ve) and Yellow (-ve)
Old Oct 14, 2014 | 01:02 PM
local38's Avatar
Default 2007 xk speaker wiring and factory sub woofer
I want to Thank You again . Your info has been a great help. I found a factory Sub Woofer mounted in the factory enclosure on Ebay but it was missing the alpine amp, so I am adding a single channel amp for the sub woofer. the sub woofer enclosure mounts under the passenger foot well carpet. there is a kick plate that you remove and under that there is a honeycomb backer made out of foam. When you remove the foam backer the factory sub enclosure bolts right in. It is a little strange that the carpet goes right on top of the speaker, not sure if the carpet needs to be cut out around the woofer grill or not. Subs always seem to be buried behind something or other. If I cant hear it after I hook up the amp I guess I will know.
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
SCMike
Sep 9, 2015 09:30 AM
obwoodie
Sep 3, 2015 07:45 PM
