2007 XK. Where is the aerial fuse?
Old Oct 22, 2023 | 06:53 PM
Brewtech's Avatar
Default 2007 XK. Where is the aerial fuse?
Had a funny day today. First a bird managed to **** on my hood, so I jumped in the car and ran the car through a quick car wash, since I wasnt home. Well, I forgot to lower the aerial because I never run a car through a carwash, and I bent it back far enough to give it a cool 45 deg angle. I disconnected the plug from it to keep it from powering up, but just curious about the fuse location.
Old Oct 22, 2023 | 07:58 PM
Sean W's Avatar
F4 in the Auxiliary Junction box behind the rear seats
Old Oct 22, 2023 | 07:59 PM
Stuart S's Avatar
Make sure that your radio is off before you remove the fuse, which is in the fuse box located behind the vertical cushion in between the rear seats. That upper cushion is secured by friction-fit pins at the top that will release with a sharp pull towards you. Put your hands on the sides of the cushion near the top and sharply pull it towards you to release it. When the top of the pad is free, lift it up and out. The auxillary fuse box is right there. Pull the 10A fuse in F4. There should be a fuse puller tool in the bottom of the fuse box.
Reinstall the cushion and have a beer!
Watch this:
Disregard the advice about removing Fuse 19 because it applies to XKR models with an active exhaust. Your XK does not have an active exhaust.
Old Oct 22, 2023 | 08:03 PM
Stuart S's Avatar
Originally Posted by Sean W
F14 in the Auxiliary Junction box behind the rear seats
I think you meant F4.
Sampson
Feb 21, 2023 09:27 PM
Chris Brindle
Jul 6, 2021 01:07 PM
law_panda
Jan 16, 2021 10:51 AM
1 of 19
Jul 21, 2017 10:03 AM
XXXAngelXXX
Jun 17, 2016 05:26 AM
