2009 XKR - What is this Sensor called?
Old May 16, 2019 | 07:31 PM
mikemusso's Avatar
Question 2009 XKR - What is this Sensor called?
Gents. Was cleaning under the engine cover for the first time since owning the car and noticed this sensor that seems to be an after thought or make shift arrangement. I moved it and the air tube was so brittle it snapped in half. Salvaged what little tubing was left with a small hose and re-positioned it.
No error codes or difference in driving. Appears to connect back to the back of the RH Supercharger bank. Searched Jag parts for hours and can't see one that resembles it.
No wires inside. Just a very small tube, Excessive heat must have hardened the tube.
Mike
Old May 17, 2019 | 09:58 AM
gkubrak's Avatar
That's the vacuum hose from the S/C outlet pipe to the fuel pressure sensor.
PN AJ811093
The other capped end is for the Secondary Air Injection. Not included in North American markets.
Old May 17, 2019 | 06:30 PM
mikemusso's Avatar
Default Big thanks!... I will be looking for a new one soon.
Big thanks!... I will be looking for a new one soon. Mike
Old May 17, 2019 | 06:41 PM
mikemusso's Avatar
PS: Do you know if the S/C end just pops off the back of RH intake? Found one online for $35 bucks.
Old May 19, 2019 | 12:29 PM
Ranchero50's Avatar
Yep, pops on a little nippl. You can go to NAPA and buy some vacuum tubing for a quick fix. All of the post '85 Fords had these little lines and they break all the time.
sjyokel
Oct 30, 2012 09:29 AM
LxTxNx
Oct 5, 2012 03:37 PM
85_305
Jan 3, 2010 01:52 PM
Alwann
Dec 7, 2009 01:02 PM
JagXType620
Aug 4, 2009 08:16 AM
