2012 XKR : Odd LED. Comes on with brake light
Old Feb 5, 2018 | 01:20 PM
Stuart S's Avatar
Originally Posted by Hailers
No. You apply brake pressure then press the start button. Common practice.
Both ways work.
Old Feb 5, 2018 | 02:20 PM
kj07xk's Avatar
Yes, common practice, but doesn't make it the best method.
My Lexus will only start with the brake-before-button method (dim-wits),
but my XK starts more reliably with the button-before-brake method.
Old Feb 5, 2018 | 02:44 PM
jagtoes's Avatar
If you think about it logic says you hit the brake and press the start would be the way the system was designed. By hitting the button 1st if you don't tap the brake quick enough the system goes into the Acc. mode turning on the infotainment and instruments. My Lexus does the same . Now being I check the oil 1st I hit the start button and do the oil check. Then step on the brake and hit the start . Now with my truck you just turn and let go of the key and it starts. No need to hit the brake. Just my observation.
Old Feb 6, 2018 | 03:19 AM
Originally Posted by jagtoes
..... Now being I check the oil 1st I hit the start button and do the oil check. .....
It's going from bad to worse. You're checking the oil level on a COLD engine!
2012 XKR : Odd LED. Comes on with brake light-oil-check.jpg
Now I understand why there's so much trouble over warranty in the US of A. Nobody takes any notice of the manufacturer's guidance.
Old Feb 6, 2018 | 07:35 AM
jagtoes's Avatar
Attachment 209798
Not to worry Graham as I had correlated the normal warm oil check with the cold check. No appreciable difference so going either way is OK. As to the manual I had read it after the 1st month of ownership and now I go to the maintenance manual for any other info. I do check after a 5 hour run during a trip but never seen the indicator move yet.
Old Feb 6, 2018 | 07:58 AM
Given Jaguar's record on the accuracy of instruments and gauges, I'm tempted to drain it to check!
That being said, neither of my XK8's (a 4.0 and a 4.2) or my earlier 4.2 XK used any significant oil between changes.
Old Feb 6, 2018 | 08:16 AM
Stuart S's Avatar
All I wanted to do was pass along the advice that my Service Advisor gave me after I depressed the brake pedal and then pressed the start button and my XKR wouldn't start. I thought his advice, which I knew was the opposite of what is in the Owner's Handbook, might be helpful to others. I never expected any controversy over his advice.
Pressing the start button first, while not mentioned in the Owner's Handbook, does no harm. I prefer it since both my XKR and XJ start easier with less cranking with just a tap on the brake pedal. And, Graham, I'm not in a race to get started; by starting faster I meant that my XKR and XJ both start with less cranking; tap the brake and they start almost instantaneously. That's less wear and tear on the starter motor and is why I've been doing it for years.
Perhaps the Owner's Handbook should be revised.
Old Feb 6, 2018 | 08:21 AM
  #28
110reef's Avatar
This is the internet. Controversy is what we do.
Old Feb 6, 2018 | 08:25 AM
Stuart S's Avatar
Originally Posted by Ranchero50
Pressing the start button wakes up the car. When the brake pedal is pushed first the car's systems are coming online while the starter motor is cranking. I've found I get less dumb stuff happening if I let the car wake up a second with the button before trying to crank it over with the brake pedal. It also seems to start faster.
I thought the car woke up when you unlocked it, either with the smartkey or by pulling the door handle. That causes the touchscreen to illuminate before either the start button or the brake pedal are depressed.
Old Feb 6, 2018 | 08:31 AM
  #30
Stuart S's Avatar
Ha! And I thought that's what Republicans and Democrats do. What do I know?
Old Feb 6, 2018 | 09:16 AM
  #31
carzaddict's Avatar
interesting, i've actually started it both ways. didnt make a difference in start times or start speeds.
the bigger issue i have with the starter is that you have to press and hold. on all other non jag cars ive owned, a slight tap on the button (and foot on brake) was more than enough to crank
bgiloni
XJ40 ( XJ81 )
Nov 26, 2016 04:44 PM
Dain
Dec 29, 2013 01:02 AM
joemac5367
Oct 26, 2011 05:46 PM
gti69
XJ40 ( XJ81 )
16
Feb 12, 2010 01:03 PM
Stuckonbrits
XJ40 ( XJ81 )
Feb 23, 2009 09:25 AM
