2012 XKR wiper blade replacement
Old Mar 21, 2022 | 06:46 PM
liquidhigh's Avatar
Default 2012 XKR wiper blade replacement
How do you do it. The wipers do not even fold out to make it easy please help.
Old Mar 21, 2022 | 09:28 PM
fxdwg's Avatar
Stick a ball under the arm to keep it raised while you change blades. Tennis ball, dog chew ball or anything the right size.
Old Mar 21, 2022 | 10:00 PM
liquidhigh's Avatar
I finally figured t out found a good video on the f type blades which are the same. It is easy once you relive to just flip up the tab.
Old Mar 21, 2022 | 10:11 PM
OzXFR's Avatar
Originally Posted by liquidhigh
I can't get the old ones off. Any quick ideas on how to r
remove them?
I am fairly sure they are the same as the F-Type wiper arms and blade replacement works the same.
Coz I year or so ago a feral ripped one of my wiper arms clean off and my mechanic replaced it with a used XK arm.
Anyway attached is a pic from the Workshop Manual showing how to unclip the wiper arm.
Using a small screwdriver or even your fingernail you gently pry up the plastic clip then you slide the wiper off the arm.
Old Mar 22, 2022 | 03:58 AM
I'm not a great fan of the current Workshop Manual 'focussed' illustrations in blue and green. The one above in post #4 is OK once you know how to do it but the old style drawing in the earlier WSM was much clearer:
A second drawing showing the end of the Wiper Arm (2) is a hook would make the procedure more obvious.
Sean B
Dec 8, 2022 07:42 AM
HaydenS
Mar 1, 2021 12:06 PM
johndahlheimer
Sep 17, 2020 03:10 PM
Teddyboy2018
Aug 9, 2019 02:19 AM
emery65038
Nov 29, 2011 08:22 PM
