2013 XK
Old Apr 17, 2019 | 08:43 AM
jwnay's Avatar
Default 2013 XK
Hello
I have a 2013 XK convertible. It only had 1 key so I went to a shop that had a guy come in and program an additional key for the car.
When I got home the rear quarter window would not come up when top was closed. Do you think the programming had anything to do with it?
Don't really want to go back to the shop because I don't think they know much about Jaguar's.
Old Apr 17, 2019 | 09:34 AM
Welcome to the forums jwnay,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XK/XKR forum. This is the place to post technical questions about your model.
Old Apr 17, 2019 | 11:18 AM
Cee Jay's Avatar
Yeah, probably nothing to do with the key. More likely the programmer didn't have enough power to run the SDD while programming the car, hence Low Battery.
Easiest and cheapest, disconnect the car battery, CHARGE IT using a GOOD battery charger (not a maintainer) of at least 10 amps for many hours. Also, while disconnected, touch the POS and NEG battery cables together for a couple seconds to drain all the volatile memory.
Once that is done and hooked back up, reprogram the front windows by holding the window button UP and hold it for at least three seconds past Full Up. Then do DOWN the same way. Then, UP again.
THEN, lower the top completely and raise it again.
That should do it.
If it DOESN'T rectify, Steve will be around shortly and he'll tell you to do a Manual Top Reset as per the Manual.
QuartzSTypeR
US Central
25
Jul 21, 2013 09:29 AM
Executive
Jun 26, 2013 10:22 AM
chacha
Jun 24, 2013 12:59 PM
GhostriderXKR08
Jul 2, 2011 04:09 AM
GhostriderXKR08
Jun 25, 2011 03:28 AM
