4.2 XKR rotational play in supercharger - normal?
Old Apr 1, 2019 | 02:14 PM
gkubrak's Avatar
Default 4.2 XKR rotational play in supercharger - normal?
After removing my supercharger for some maintenance and repairs (not related to the supercharger), I noticed something odd...
While holding down the rotors, i was able to rotate the pulley about 5 degrees clockwise (viewing from front), while the rotors remained stationary. I can't imagine the shaft would be torquing like that.
Is this normal???
Thanks !
Old Apr 1, 2019 | 03:40 PM
Ranchero50's Avatar
I'd pull the snout off and expect to replace the rubber coupling if not the metal parts. It's basically a little lovejoy setup.
Old Apr 1, 2019 | 03:54 PM
Cee Jay's Avatar
Same S/C as the 5.0, right?
https://www.jaguarforums.com/forum/x...olator-137560/
Old Apr 1, 2019 | 04:34 PM
gkubrak's Avatar
That service bulletin says its only for the 2010+ models, so I'm not sure they are the same design.
I really don't want to take the snout off since I already replaced the fluid, and I would be too temped to just rebuild the whole thing.
But seeing this pic of the inside of the 5.0 S/C makes me think its normal. I'm guessing that torsional spring is what I'm feeling.
Edit: I have never had any issues or abnormal noise from the S/C, which also leads me to believe it's normal.
Old Apr 1, 2019 | 10:37 PM
Tp10XKR's Avatar
Do yourself a big favor and replace the coupler with a solid aftermarket one. The caddy guys are all doing it with the LSA motor and not looking back
Old Apr 2, 2019 | 01:10 PM
Sean W's Avatar
consider taking your question over to the S-Type or X350 forum. A lot of DIY'ers over there that can probably give you the answer you need.
wilsongsx
Feb 8, 2018 11:28 PM
Lubino Do Rego
Aug 13, 2016 01:47 AM
hotelfoxtrot
Mar 16, 2016 01:27 PM
cyber3d
Jan 18, 2016 04:02 PM
bgshaw
Apr 2, 2015 05:39 AM
