5.0 Engine - Bigger Supercharger etc; Has it been done?
Old Jan 13, 2015 | 05:36 AM
Frizzle's Avatar
Default 5.0 Engine - Bigger Supercharger etc; Has it been done?
Hi guys,
Does anybody know of a Jaguar with the 5.0 supercharged engine running modification over and above the usual pulley/remap?
I'm guessing the next stage would be a different supercharger - Maybe the larger Eaton TVS2300 supercharger?
Not sure how strong the internals are on these motors, but I'm guessing 700hp shouldn't be too far away.
Old Jan 13, 2015 | 10:10 AM
Lothar52's Avatar
Its the same V8 doing 575 on the Project 7 so we know it can do MORE then the 550 in the XKR-S and the F-Type R so we know its got legs... I would think they could mod some things and bump it above 600??
Old Jan 13, 2015 | 10:20 AM
andys-GR's Avatar
I'm sure I read somewhere, it may have even been on here that Jaguar had claimed to have got 750bhp out of the stock (internals) V8. Its seems entirely feasible 100bhp per liter is very low for a forced induction motor.
Old Jan 13, 2015 | 07:27 PM
DGL's Avatar
DGL
With a simple tune and pulley change the hp can be increased to 620hp. I'm sure with other bolt on mods the hp could be increase to over 700hp. However, the XKR has difficulty putting 510hp to the pavement. Another 200 hp will be insanely scary.
Old Jan 14, 2015 | 10:34 AM
Frizzle's Avatar
Yeah the engine is already very tuneable with just a map and pulley, and like you say traction is an issue as stock! But it would be interesting to see how far it could be taken using simple bolt on mods; well designed intake, full exhaust system etc.
The gearbox is an unknown as well, I know it's rated at 700NM, but how conservative is that rating?
Old Jan 14, 2015 | 06:33 PM
Ngarara's Avatar
You'd want an R-S gearbox - the 75 and R-S have an uprated torque converter.
Old Jan 17, 2015 | 08:47 AM
RainsFather's Avatar
What size TVS is stock?
Old Jan 18, 2015 | 11:51 AM
Rey's Avatar
Rey
Suggest you check the XK8 Forum. Some members have upgraded superchargers to another brand (Kenne Bell?) with great results. We share the same basic motor, except for direct fuel injection.
There is a member on the XK8 Forum (Arvos or Avos) who sells a kit for XK8. He may be able to market a kit for the XKR. Whatever, I think he has a wealth of info on supercharger upgrades/changes.
Often overlooked by tuners are upgrades to intercoolers. There is usually some room for improvement.
Old Jan 18, 2015 | 11:53 AM
Ngarara's Avatar
Stock blower is a TVS 1900
Old Jan 18, 2015 | 06:37 PM
CleverName's Avatar
Originally Posted by Rey
Suggest you check the XK8 Forum. We share the same basic motor, except for direct fuel injection.
It was my understanding that the 4.2 and the 5.0 share nothing... (Two totally different designed motors.) Am I in error?
Vince
Old Jan 18, 2015 | 06:47 PM
Cambo's Avatar
Vince
No you're right, there's no shared parts between the 4.2 & the 5.0, maybe a bolt or two, but that's it...
There seems little need to upgrade the supercharger on the 5.0 more that just fitting the pulley. These engines can make >625HP with the standard blower + pulley/tune. With extra tweaks like cats, intakes, I think 650HP is the upper limit for what can be done cost effectively.
Maybe a more efficient twin-screw could get you a bit more, but for the time & costs involved, it's not worth it.
The layout of the supercharger, throttle body & charge coolers is totally different on the 5.0, it wouldn't be as easy to adapt a twin screw like it was with the 4.2.
Old Jan 18, 2015 | 07:14 PM
I would think upgrading to the tvs2300 would be much easier and could produce much more power than the fuel system and internals could handle. Finding someone that could tune for e85 with stock blower would be the direction I would go if the fuel system can keep up.
Old Jan 18, 2015 | 07:38 PM
Cambo's Avatar
You need a blower with front drive, front inlet, & top outlet that will physically fit in the slot where the stock one goes. That's not an off-the-shelf item anywhere...
Here are some pics of the TVS R1900 off the 5.0, it is completely unique to JLR. Trying to package a "universal" blower into the available space with a shaft drive down the side...good luck...
And for the money involved to get Magnuson or Harrop to make you a one-off custom TVS2300 (probably $15-$20K) you will get maybe 50HP, not worth it...
Kenne Bell has said "we will not make backwards superchargers" so no chance with them.
So it's all custom work, which is $$$$'s
Old Jan 19, 2015 | 01:33 AM
ccfulton's Avatar
Thanks Cambo, I had not seen the JLR version off of a car. That is a strange beast.
Ever seen one with the snout and front cover off? I'm having a hard time imagining how you get the gear drive in there without having some torturous path for the air to follow.
Just for comparison, here is a Kenne Belle 2.6L and the 4.2L setup. As Cambo said, totally different.
Old Jan 19, 2015 | 02:24 AM
Cambo's Avatar
Never took the snout off Charlie, but I did take a picture down the throat of it.
That goop is obviously not from the factory, someone had opened this one up earlier.
Old Jan 19, 2015 | 03:00 AM
ccfulton's Avatar
Interesting.
Given the sort of oddly squished shape of the inlet, wonder if it might benefit from porting/polishing.
Clearly it doesn't have too much trouble breathing, but seems like it couldn't hurt.
Old Jan 19, 2015 | 08:50 AM
XJR-99's Avatar
Arden offers 5.0 TS kit. Makes 680bhp. Includes stronger pistons, additonal ECU and exhaust including high flow cats. This kit if for those who does not care about the money spent so much http://shop.arden.de/jaguar/jaguar-f...orkit-kit.html
Here the kit in a Range Rover:
Old Jan 19, 2015 | 08:55 AM
R_Rated's Avatar
Save your money and get a Ferrari California
Old Jan 19, 2015 | 12:15 PM
mosesbotbol's Avatar
I have read mixed reviews on Arden's products for Jaguar. I'd be hesitant to spend so much with such a potential bad outcome.
Old Feb 17, 2015 | 09:45 PM
Tijoe's Avatar
I wanted to add more information to this post. There is a new version of the the TVS1900 superchargers being used for the past year or two. Jaguar and Rover have moved away from a vacuum operated bypass valve to an electrically controlled bypass valve. Just something to think about if someone ever decides to try to swap superchargers on the newest Jaguars. (See images. First image older version next to new version. Second image latest version with electronic bypass actuator.)
As a follow up,of one of the earlier posts, I looked into putting the Jaguar 5.0 TVS1900 supercharger onto the 4.2 block. Very very difficult! The throttle body inlet sits right over the block's water outlet elbow. If would be a great way to go on the STR engine, but much easier to go with AVOS's twin screw upgrade on an STR.
Attached Thumbnails 5.0 Engine -  Bigger Supercharger etc; Has it been done?-img_0751.jpg   5.0 Engine -  Bigger Supercharger etc; Has it been done?-img_0753.jpg
