5.0 Timing Chain- New Information. Attn Techs
Old Dec 1, 2022 | 08:18 PM
  #101
JagRag's Avatar
Originally Posted by tarokyama
Does oil viscosity affect chain noise on cold start?
wondering if I should switch to 0W-20 from 5W-20 to reduce cold start chain noise.
I have done a oil flush recently, no changes from that.
Dude you live in Hawaii not in Minnesota.
Old Dec 1, 2022 | 08:56 PM
  #102
trkyam's Avatar
Valid point Lol
Old Dec 6, 2022 | 08:26 PM
  #103
viper1996's Avatar
Originally Posted by Lothar52
The timing chain was changed to a different brand sometime between the 2012 model year in the US and the 2013 model year in the US. Apperently the 5.0 engine does a great job at eating the chain and causing problems. It was best they do so after having so many awful noises to have my chain, chain guides/tensioners, and all 4 actuators replaced at the same time after the previous attempt. Thats alot of changing to moving/noisy parts and it is no wonder now with all that changed out that my Jag sounds BRAND NEW up front. I also had the supercharger problem with it eating itself in the last year that was completely replaced as well..... engine dropped 3 times, taken apart 4... hopefully I can get her to 100,000 miles from 30,000 miles clean and dandy
Loth
Yes that is what I heard also...some say not true...
Old Dec 7, 2022 | 07:49 AM
  #104
kansanbrit's Avatar
There never has been a problem with the actual chains. Most people pay a lot of money to have parts changed that don't need changing.
Old Dec 7, 2022 | 10:27 AM
  #105
viper1996's Avatar
The point being that the problem was corrected in around 2013 Tensioners guides whatever
Old Dec 7, 2022 | 10:47 AM
  #106
kansanbrit's Avatar
Not that simple, two different chain types, very earliest design was the best of all in my opinion, with a plastic insert in the guides and much higher standard of components generally. This my 2010.
Old Dec 7, 2022 | 12:35 PM
  #107
JagRag's Avatar
So the early 2010's (all 2010's?) and possibly the 2011's have the best design and components then??? Is this correct?
Old Dec 7, 2022 | 01:37 PM
  #108
kansanbrit's Avatar
Don't know, just know mine (2010) has what I believe to be the best. 6.35mm pitch. Of course it's possible that it was changed before I bought the car but I doubt it and I have never seen these components on any of the other 5.0 engines I have worked on.
A lot of info on this on the XFR X250 forum.
Old Dec 9, 2022 | 05:27 PM
  #109
trkyam's Avatar
my 2010 has same chains/guides as well, wider more robust, better engineered.
Old Feb 16, 2023 | 04:00 PM
  #110
kyshaew's Avatar
Angry Timing chain replacement
My 2015 XJ been at the Land Rover Jaguar Dallas dealership for over 2 weeks now. I took it there for diagnostic and was told the timing chain is loose and I should replace the entire engine.... is there and reputable shops in DFW area that can repair my car.
Old Feb 16, 2023 | 05:24 PM
  #111
trkyam's Avatar
how many miles on it? whats the maintenance history?
I would verify this by carefully inspecting the chain with the engine running through the oil filler cap, (carefully)
also with the engine off using a screw driver to poke at the chain and look for play.
Old Feb 17, 2023 | 03:23 AM
  #112
RichardS's Avatar
Apart from any noise from the timing chain, was the engine running reasonably OK? If it was then it is highly unlikely that the pistons/valves are damaged and all the engine needs is a new chain and tensioners which is not a particularly difficult job.
If the engine was running badly and there had been any banging or knocking noises, then get the cylinders compression tested and/or inspected with a borescope. Once again, a relatively simple job and essential before taking any decision about a new engine being required.
Richard
Old Feb 17, 2023 | 02:34 PM
  #113
waldo's Avatar
I would contact British Auto Specialists, British Auto Specialists |, and see what they can do for you. They’re just northeast of Fort Worth.
SinF
Aug 30, 2019 07:57 PM
Mr happy
Mar 22, 2017 11:13 PM
byjosh
Apr 1, 2016 02:11 PM
Visinedrops
Apr 4, 2009 10:05 AM
n17gary
Mar 11, 2009 04:28 PM
